Home: Lathes, Lathe Rebuilding & Conversions
General discussion for lathes, lathe usage, rebuilding, operation and conversions.
Page 1 of 7 123 ... LastLast
Threads 1 to 20 of 127
Sub-Forums Threads / Posts  Last Post
  1. Here you can find the conversion build logs/diaries of machines that have been converted to cnc by our members.
    Forum Actions:
    Forum Statistics:
    • Threads: 8
  2. Here you can find the lathe rebuild logs by our members.
    Forum Actions:
    Forum Statistics:
    • Threads: 12
  3. General discussion for the Emco brand of Lathes.
    Forum Actions:
    Forum Statistics:
    • Threads: 11
  4. General discussion for commercial Boxford lathe Machines.
    Forum Actions:
    Forum Statistics:
    • Threads: 62
  5. General discussion for the Acorntools, Atlas and Halifax brands of lathes.
    Forum Actions:
    Forum Statistics:
    • Threads: 1
  6. General discussion for the Conect (121, Cadet ect.) range of cnc lathes.
    Forum Actions:
    Forum Statistics:
    • Threads: 11
  7. General discussion for commercial Clarke lathes.
    Forum Actions:
    Forum Statistics:
    • Threads: 3
  8. General discussion for Mazak and/or Yamazaki branded lathes.
    Forum Actions:
    Forum Statistics:
    • Threads: 4
  9. General discussion for the Denford range.
    Forum Actions:
    Forum Statistics:
    • Threads: 17
  10. General discussion for the range of lathes by SIEG.
    Forum Actions:
    Forum Statistics:
    • Threads: 3
  1. Turning issues
    Started by knucklebones, 13-03-2024
    27-03-2024 Go to last post
  2. Hardinge Lathe CNC Retrofit/Conversion
    Started by Chaz, 24-09-2020
    14 Pages
    1 2 3 ... 14
    14-01-2024 Go to last post
  3. Lathe suggestions?
    Started by routercnc, 15-10-2015
    8 Pages
    1 2 3 ... 8
    29-12-2023 Go to last post
  4. Emco PC Turn 55 V00
    Started by JohnT, 15-12-2023
    15-12-2023 Go to last post
  5. Colchester 500 with fanuc3T
    Started by danby, 25-02-2023
    25-02-2023 Go to last post
    04-01-2023 Go to last post
  6. harrison l5 change gears
    Started by aquarius, 18-12-2022
    18-12-2022 Go to last post
    07-11-2022 Go to last post
  7. Amadeal CJ18A CNC Conversion
    Started by djbsystems, 29-09-2022
    29-09-2022 Go to last post
    25-09-2022 Go to last post
  8. Still having problems.
    Started by terry1956, 18-09-2022
    18-09-2022 Go to last post
  9. Problems with lathe
    Started by terry1956, 21-08-2022
    2 Pages
    1 2
    23-08-2022 Go to last post
    22-08-2022 Go to last post
    15-04-2022 Go to last post
  10. DC motor controller
    Started by MrHappy, 06-01-2022
    23-01-2022 Go to last post
    10-01-2022 Go to last post
    07-01-2022 Go to last post
    01-08-2021 Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
