25-12-2019 #41
25-12-2019 #42
The plastic mounts for the limit switches I printed will actually slide down the rails and the extrusion if the gantry goes up against them (provided i use plastic slot nuts that I've designed and printed that will secure the mounts in place up until a certain amount of force). I could modify the print so that the rail carriages come into contact with the mounts after the limit switch is activated so it would slide the mounts and activated limit switch out of the way without damaging them. Behind this I could put a buffer as you suggested. I think this would work and if things did go tits up I'd notice it happening if I was looking. The mounts are cheap to reprint if they do get damaged. Next question is... is it worth using one off those PILZ relays to cut PSU/mains voltage off and does this stop movement quicker?
Thanks for all the advice.
25-12-2019 #43
Then you have all the hassle of setting back up again and I don't think you realize just how many times or how easy it is to smack a limit when new to CNC and setting a machine up for the first time. To be honest I don't see the problem with making them slide past and do away with the hassle.? They also work better IMO but that's open to debate which I'm not getting into.
Regards the Pilz then you don't need it at a hobby level and while it might detect a mili sec or two quicker that won't change anything because it's inertia you are dealing with and couple of mili secs of movement is nothing.
26-12-2019 #44
Probably won't bother with a Pilz then at least for now. I could make it so the limits / home are sideways on. I'm still a fair way off sussing out how to position the other axis switches but i do have options. I'm new to this lark and my preconceptions and concerns about damage have been more focused on the machine frame / bearings and ball screws etc as this would be more catastrophic and expensive. I really appreciate advice based on actual experience and I'm in no doubt that i haven't done enough research to get things right first time. Which ever way my machine turns out i'l certainly be keeping an eye on it especially when I'm cutting stuff that goes near the edges of the bed.
26-12-2019 #45
One of the main dilemmas with any DIY project is working out where best to direct the inevitably limited funds. Having never heard of a PILZ relay before I did a quick search and seeing what you have to pay for one, I agree with Jaz. You don't need one!
The Following User Says Thank You to Kitwn For This Useful Post:
27-12-2019 #46
31-12-2019 #47
WiringDia_compressed.pdf
So this wiring diagram is how the home switch works. Next question is how do I wire two of the same NPN NC switches in series to act a limit switches.
Regards Chris
31-12-2019 #48
You are using an IP-M why would you wire them in series you're not short of inputs surely.? Wiring prox switches in series slows there reaction time so it, if not needed, wouldn't do it.
However, if you must do it then simply take the Signal wire (black) from first switch to the (0V) on the second and repeat for any further switches in wired series. On the last switch take the Signal to the IP-M (-)input.
28-06-2021 #49
Which one did you get? Im looking to get a few as well.
28-06-2021 #50-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Proximity wiring for limit switches, safety relay and a contactor
By CharlieRam in forum General ElectronicsReplies: 15Last Post: 02-06-2019, 11:18 PM -
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
Help needed with proximity switches
By Boyan Silyavski in forum General ElectronicsReplies: 6Last Post: 11-07-2014, 03:29 AM -
Proximity Switches
By kingcreaky in forum General ElectronicsReplies: 20Last Post: 23-10-2013, 01:30 PM -
Proximity Sensors as Limit Switches ?
By Lee Roberts in forum General ElectronicsReplies: 5Last Post: 03-10-2009, 07:04 PM
