    What driver do you recommend to power a Nema 14/17 I don't want to use the A4988's as this runs 24 hours a day I just don't trust they're up to it. I need good positional accuracy 0.1mm over a rotation (It's geared 4:1 so 800 steps) works I will have a home switch will I'll use to track and correct drift if it happens
    But if I'm getting drift something is wrong and needs to be fixed it'll be interference.
    Home is more there in case of power off I can recover where I was
    It take X steps takes a photo, logs it's position to a file and then takes another X steps. I can use the log to restore to original position in case of power off
    It's a timelapse BUT timed to steps NOT time
    TB6600 sound OK? I don't want to spend a lot but it does need to be accurate and capable of running 24/7 for weeks at a time
    It's rotating a lazy Susan, rotation rates will be very low as should torque
    Lives in East Lothian, United Kingdom. Last Activity: 2 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    Do the TB6600 go to low enough current for the motor?
    I had planned to used TB drivers for desktop engraver, but ended up with DRV8825 drivers.
    The small driver chips are fine as long as you're not pushing them to their limit.
    Hi this is the motor
    https://www.aliexpress.com/item/1005005433808105.html
    TB6600 on the datasheet is 0.7amp-4amp
    If I read the datasheet right the Nema 14 is 1.8amp
    They sell them for 3d printer direct extruders so have more torque than average Nema 14 frame motors
    I want something neat to wire too as well the little drivers how the hell do I mount them nicely???
    I'm using din rail PSU's and relays to keep everything neat
    So so many relays that poor little Pi.....
    I have bought the listed motor I cancelled the TB6600 after watching videos of people bitching about them lol
    It's just a pity i suck so hard at programming as that's going to be a bitch
    I ended up using a CNC shield with jumper wires to use the little drivers, but have added making a custom BOB for them on to the roundtuit list.
    TB6600 drives are OK if you get genuine ones, and don't push them too hard by running near the maximum voltage.
    The 'fake' ones, don't even use a TB6600 chip. You can usually tell the fake ones, as they have a 32x microstep setting, which the TB6600 chip isn't capable off.
    I'm using A4988 in the end after researching I just have to make my own PCB lol
    Not really that complicated I bought a PCB board from Ali, some sockets, resistors, pin headers ,etc
    So I'm going to socket the A4988 before it connects to the Pi which means i can just swap another one if it fails they're cheap and I have multiple
    BUT I went with them because for the kind of motor I have these give best microstep performance for resolution as long as you have more than enough torque
    They also work at 3.3v for step/dir without having to wire in a transistor as the PI is 3.3v at the GPIO pins
  1. Low torque steppers Nema 14
    By Desertboy in forum Stepper & Servo Motors
    Last Post: 13-12-2023, 08:16 AM
  2. DM860H driver and NEMA 34, 6 A, 8.5 Nm - configuration
    By Emir in forum Motor Drivers & Controllers
    Last Post: 01-04-2023, 02:40 PM
  3. Help sizing your motor power and torque application
    By Gary in forum General Discussion
    Last Post: 14-12-2019, 11:25 AM
  4. Csmio-IPM wiring A nema 17 TB6600 driver Z axis THC
    By Copypaste in forum CS-Lab (CSMIO)
    Last Post: 14-02-2019, 08:41 PM
  5. Replies: 0
    Last Post: 24-09-2014, 09:57 AM
