Thread: chinese atc spindle ?
Waiting on the uc300 eth motion controller and ucbb breakout Broad to be delivered for a uccnc upgrade,,, it also came with a uccnc licence,,,,,,,got an option for a new Hiteco hsk 63f spindle,,,,,,anyone using this type?
22-02-2020 #12
HSK63 is bit on the large side for a router but it will certainly do the job, thou tool holders are expensive compared to say BT40. For instance, I just looked on Cutwel site and HSK60F ER32 collet holder is £102. BT40 ER32 is £17.30.!
HSK is much stiffer but to be honest it will be wasted on a Chinese router so unless it's same or not much more money, then because of the much more expensive tool holder then I'd probably give it a miss because 10 tools, which sounds a lot but for ATC it's not, will cost £1K+ compared to £200 or less. BIG Difference.
24-02-2020 #13
I've noticed from some of your other machine builds that you are using a fixed BK12 bearing in both ends of the X-axis (don't know about Y-axis). What is the reason for that?
Also in this video, you are not using any floating bearing on the Z-axis. Is it not needed because of the very short Z-axis length?
24-02-2020 #14
I do this on all ball-screws longer than 1000mm on both X & Y. The reason is to lower ballscrew whip, 2 fixed bearings provides more support and also allow the screw to be pre-loaded with tension.
Not required on ball-screws less than 350mm.
24-02-2020 #15
24-02-2020 #16
25-02-2020 #17
21-10-2020 #18
Hi Jazz,,
I live in the US and I purchased a similar Chinese 4.5KW BT 30 ATC spindle.
I built my own CNC and after having several successes in manufacturing parts (For about two years now) I have decided to add an ATC to my machine.
The problem that I’m having is that I can hardly find any help on how to connect this item.
It cost about $2000 and I don’t want to short it or break it since there is no warranty for noobs like me.
I am not a professional CNCer and everything I’ve learned about it have been on YouTube from people like yourself. It is a hobby that I truly enjoy and hopefully I could someday earn a little bit of money from it, however for now, it is only a hobby.
Could it be possible that you can help me with my questions?
Any help will be greatly appreciated.
Sincerely José Ricardo
21-10-2020 #19-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
21-10-2020 #20
ATC Questions
Hi Jazz,
Thank you for your time.
My my questions revolve around The electrical connections and the pneumatic connections.
Power supply, Thermal, Fan
The manual says:
9 pin plug
1. Thermal: 1, 5. What wire do I connect here? From where?
2. Fan: 3 Black,9 Red. What wire do I connect here? From where?
3. Power supply: 4 Red U,6 Black V,8 Blue W. GOT IT VFD.
4. Ground: 2 Yellow,Green. GOT IT from VFD.
Proximity switch
Switch button
11 Pin Plug
Hanging knife: 1 5 Red
Unloading knife: 2 11 Red
0V: 6 Blue 7 Blue
24V: Brown 8 Blue
5. What is hanging knife: 1? What do I connect here? From where?
6. What is unloading knife:2? What do I connect here? From where?
7. 0V: 6 Blue. What do I connect here? From where?
8. 24V: Brown What do I connect here? From where?
Do I get the 24V from outside source?
Which Pin is this? What does it do?
Switch button (it’s a little red button with two wires NC (I can only assume is to engage solenoid solenoid to drop the tool) What does it do?
9. 5 Red. What do I connect here?
10. 11 Red. What do I connect here?
11. 7 Blue. What do I connect here?
8 Blue. What do I connect here?
I contacted the company that sold me the spindle but you know, Chinese. They just basically told me to find my own engineer.
In reference to the pneumatics, I have one 1/4” connection and two 4mm connections. I’m not sure where these go.
Again, thanks a lot For any help you can provide on this.
Jose Ricardo
Chinese VFD and 2.2Kw Spindle
By JackDavies in forum Spindles & Drive MotorsReplies: 6Last Post: 09-01-2019, 08:04 AM -
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
FOR SALE: 1.5kw chinese spindle with VFD
By discodave in forum Items For SaleReplies: 0Last Post: 17-06-2014, 07:05 PM -
WANTED: Chinese 1.5kw spindle/vfd
By Philly in forum Items WantedReplies: 5Last Post: 10-02-2013, 11:44 AM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
