    Hi, I’m still in the design phase of building a small cnc mill.
    I was thinking oh getting two 600X400X100 granite surface plates
    And bolting them 90deg to each other as the bad of the mill.
    Has anyone tried this method,
    My worry about the plates is that the Z axis plate might break
    Or shatter with the force of the spindle and also the overhang
    Of the spindle. The plates will be the cheap version and are about
    300euro each.
    Why not buy a mill and bolt some motors on it?
    A few years back there were some articles about adding rigidity and mass to the small X1 mill by filling the hollow square column and also the base casting with epoxy concrete. Using an existing structure gives you a good starting point. You could also use standard aluminium or steel sections and fill those with epoxy-concrete, I believe this approach is used in industrial machines.
    I think using lumps of granite will be fraught with problems - they are only finished flat on one face I guess so you couldn't rely on the edges being square or parallel. They are heavy to handle, hard to drill, and not strong in tension.
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 15 Hours Ago Has been a member for 9-10 years. Has a total post count of 788. Received thanks 97 times, giving thanks to others 176 times.
    There was a post on the forum showing a build of an epoxy granite mill, the full article is over @ model engineer https://www.model-engineer.co.uk/sea...0mill&Refine=1
    It is well worth the effort to try and find this as the construction method is spot on.
    Regards Mike
    PS try a search for laser levelling as well the gentleman (believe it's John from down under) also contributed to that thread
    PS found it try searching John McNamara on the ME site
    https://www.mycncuk.com/threads/1235...illing-machine
  1. RFQ: RFQ: Surface Planning in Aluminium Cast Tooling plate
    By Delan in forum Projects, Jobs & Requests
    Last Post: 01-04-2022, 02:03 PM
  2. granite plate & steel frame
    By vre in forum Milling Machines, Builds & Conversions
    Last Post: 12-02-2020, 08:25 AM
  3. Replies: 0
    Last Post: 07-03-2019, 05:51 PM
  4. Granite devices IONI
    By Ross77 in forum Motor Drivers & Controllers
    Last Post: 12-02-2018, 11:45 AM
  5. Granite Surface Plate - Cracked?
    By camhguh in forum Workshop & Equipment
    Last Post: 27-11-2016, 02:57 PM
