    Does anyone know the UC300 "Digital Dream" controller card by Novusun? For each axis, it has Pulse +/- and Dir +/-, no 5V output. The stepper drives that I have only takes a 5v input and step and dir (see attached image). Is it possible to wire these drives to the controller?
    Many thanks 🙏.
ID:	31923Click image for larger version.
Name:	Screenshot 2023-07-08 at 21.03.19.png
    Lives in East Lothian, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,911. Received thanks 360 times, giving thanks to others 8 times.
    It should work if you provide 5V to the drive + pin (5V needs to have a shared gnd with the controller), then only connect the step/dir - outputs to the drive Step/dir inputs.
    Guess I'll need to get a 5v supply because there is nothing on the controller :(.
    Thanks for the reply!
    Check the COM+ pin for 5V
    If you need a 5 supply then a USB wall wart is a quick and cheap solution - old phone charger.
  1. FOR SALE: Steppers,drivers.etc,etc.
    By molliemilo1 in forum Items For Sale
    Last Post: 18-10-2019, 08:57 AM
  2. Uc300 motion controller problems
    By Hellfire in forum CNCdrive (UCCNC)
    Last Post: 07-11-2016, 07:21 PM
  3. Help wiring M60STH88-3008DF Steppers Motors to 752 Drivers
    By Mad Professor in forum Stepper & Servo Motors
    Last Post: 01-09-2011, 10:09 AM
  4. Has anyone used these steppers or drivers?
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 24-03-2011, 02:24 PM
  5. Steppers and drivers
    By Davidh in forum Motor Drivers & Controllers
    Last Post: 12-06-2009, 05:59 PM
