Home: Other Machines & Building
Here discussion is about 3d printers, 3d printing machines, machine usage and building your own.
Threads 1 to 9 of 9
Sub-Forums Threads / Posts  Last Post
  1. Here discussion is about 3d printers, 3d printing machines, machine usage and building your own.
    Forum Actions:
    Forum Statistics:
    • Threads: 48
    1. General discussion for the Denford range.
      Forum Actions:
      Forum Statistics:
      • Threads: 1
  2. Discuss commercial machines, the build logs/diaries of your own diy cnc pick and place machines and more here.
    Forum Actions:
    Forum Statistics:
    • Threads: 10
    1. Here you can find the build logs/diaries of machines built by our members.
      Forum Actions:
      Forum Statistics:
      • Threads: 1
  3. General discussion for anything related to moulding machines and mould making.
    Forum Actions:
    Forum Statistics:
    • Threads: 30
  4. Discuss the building of diy cnc hotwire foam cutting machines, post your build logs/diaries here as well.
    Forum Actions:
    Forum Statistics:
    • Threads: 7
  1. BUILD LOG: Roland MDX Z Up Position problem
    Started by Hobicnc, 10-09-2023
    10-09-2023 Go to last post
  2. Roland MDX-30
    Started by Portland Jon, 06-05-2022
    06-08-2023 Go to last post
    26-10-2020 Go to last post
    19-10-2020 Go to last post
  3. BUILD LOG: Multifunction arduino robot - beginer
    Started by Radu_Andrei, 19-11-2019
    3 Pages
    1 2 3
    02-12-2019 Go to last post
    19-12-2018 Go to last post
  4. Wire EDM machine
    Started by Neale, 10-08-2017
    4 Pages
    1 2 3 ... 4
    05-11-2018 Go to last post
    09-06-2018 Go to last post
    08-06-2018 Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
