Thread: Best anodizing guide?
Thanks for all the info guys!
Don't know if I replied to the email or not, but thanks for the PDF!
Finally get to start reading it tonight.
As for power supply. I already had the DPS5015 though never go around to building the whole thing with PSU. So grabbed a 48V 10A 480W cheapo from eBay and that should arrive next week.
I have had pretty good luck with these supplies so far. Have about five 12-24v ones but no 32-48v ones.
27-09-2017 #2
What are you guys using for heating the baths?
And what material should the containers be? PP should be alright?
[edit]
https://imgur.com/a/1kwXy
This guy does not use heat for the dye, I am guessing the heat helps?Last edited by JOGARA; 27-09-2017 at 03:31 PM.
27-09-2017 #3
I've never got as far as setting up an anodising line, as I'm struggling for space, and never did find out the legalities of disposing of the waste.
When I looked into it, I was going to just buy one of the Caswell kits so I knew everything would work, however I see they only offer the one kit now, and is quite a bit more expensive than what I remember.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
28-09-2017 #4
You don't need to heat the acid bath really, in fact in general the colder it is the better the result.
I often see other stages using an aquarium heater or other similar submersible heating element. This would certainly get things warmed up quickly enough!
http://www.ebay.co.uk/itm/like/26138...6331929&crdt=0
01-10-2017 #5
From what I read you don't want the acid hot at all. Both the etch and/or the anodizing tanks should be room temp as those processes get hot when reacting/putting amps though them.
The Desmut, Colour and Seal should be heated though...
Going off the Ron Newman guide that m_c sent be lists this;
- Polish part using fine sand paper for shiny finish, or wire wool for matte (can also etch for a little longer for matte finish/hide imperfections)
- Cleaner @ 140F 5 mins
- Rinse (de-ionized water)
- Etch in Lye for 10-30 seconds @ room temp
- Desmut @ room temp 1-3mins
- Anodize at room temp based off 720 rule
- Dye @ 140F for 15s-15m
- Seal @ 180F
- Hang to dry for 24 hours
Other guides I have seen do mostly the same procedure, though one suggested using "Sodium Bisulfate/Sodium Hydrogen Sulfate" instead of Sulfuric which I guess is safer?
As for heating the buckets, I like the one you linked, but I am limited on power in my current workshop. Wont be in my new one till end of November.
Pretty much can't draw more than 3000w in total.
Thinking of getting a couple 12v ones that I can then use one of these cheap controller boxes with. Safer too as those immersion ones don't always have earth on the metal case.
https://www.ebay.co.uk/itm/172822446...r=471604592191 (This is 220v ones yes, they do 12v too)Last edited by JOGARA; 01-10-2017 at 07:20 PM.
02-10-2017 #6
02-10-2017 #7
The specific heat capacity of water is 4.184 joules/gram/deg, so to raise 5 litres of water from 20 to 80 degC, would take 1255200 joules (4.184 * 5000 * (80-20)), or 0.349 KWh. Now if you've only got 120W, that means it would take 2.91 hours (0.349 / 0.12) assuming you have zero heat loss.
However, unless you've got insulated containers, I'd doubt you'd ever get to 80degC.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
03-10-2017 #8
If you have a mains thermostat just tape the probe to the outside of the bucket accuracy will be good enough.
I use these
http://www.ebay.co.uk/itm/220V-10A-M.../142426824134?
daily very reliable never had one fail over 5 years.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
03-10-2017 #9
I presume that as long as the temps are in the ballpark around 120-140F then it is okay? Don't have to be so bang on?
[edit]
Multi buy, 3 for 2 https://www.ebay.co.uk/itm/292039778...r=591027809178Last edited by JOGARA; 03-10-2017 at 10:59 PM.
12-10-2017 #10
Not sure what I am doing wrong...
But the dye is not sticking, and from the looks of it not absorbing into the part much if at all.
When I spray with water it just all falls off.
I know black can he hard to work with as the ink bits are quite large.
Not sure what to do...
Here is a part that is not been tumbled. It has been through the system before the dye bath.
As you can see, I hope, it does look like it is anodizing. This part was shiny on the flats before starting the process.
Yet Another Noob. Looking for Kit or Guide
By RatherBeMaking in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 09-04-2015, 09:52 AM -
Idiot's guide to Dolphin?
By m_c in forum DolphinReplies: 7Last Post: 18-12-2013, 02:42 PM -
DIY CNC Safety Guide
By tati in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-08-2013, 12:02 PM -
First Experiments Anodizing Aluminium at Home
By h4ppy-chris in forum Metal Finishing TechniquesReplies: 11Last Post: 13-02-2011, 01:10 PM -
SMD-How to guide?
By Ross77 in forum General ElectronicsReplies: 12Last Post: 17-08-2009, 06:43 PM
