hi gary asks for help to install stepper motor
voila all the schema with light green driver
05-10-2009 #2Visit Us: www.automationshop.co.uk
05-10-2009 #3hello Gary
Yes the drive shaft is blocked I can not even turn by hand
the engine makes noises and not running
[email protected]
05-10-2009 #4
I suspect that you are not getting a clock pulse from your parallel port.
Can you put a 5V on the clock + on the driver, you can use some small batteries in series.
Pulse it between the Pul+ and Pul- and if the motor steps, you know that you are not getting a pulse from your parallel port.
Are you using a laptop or desktop?Visit Us: www.automationshop.co.uk
05-10-2009 #5
I fail to understand I think I have the perfect facility for your pattern (see photos)
and the computer I bought a new desktop computer with win xp
and to map the parallel small red light it not light
[email protected]
06-10-2009 #6
I think Gary wants you to manually control the step lines to see if, when you connect it to +5V, the motor tries to move, or whether it doesn't move.
The controller you've got looks like it has the pump charge circuit on it - this means the computer must provide a constantly varying signal on the STROBE pin (pin 1) of the parallel port. This can normally only be done if you are running CNC software that is capable of driving it - and you've enabled it in the software.
However, having said that, it may only just drive the enable output on the parallel port interface (which would then be connected to your drivers).
The pump charge tries to prevent the motors from being moved during startup/shutdown of the computer. Manually wiggling the clock line will definitely override it.
06-10-2009 #7Visit Us: www.automationshop.co.uk
06-10-2009 #8
thank you for
Gary - audioandy - Tribbles
Finally I turned the engine problem is my parallel cable
Now I'm starting a production of my 1rst cnc machine
[email protected]
06-10-2009 #9
Good, happy cutting.
06-10-2009 #10
thank you very much
[email protected]
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper motor help.
By Kammo1 in forum Stepper & Servo MotorsReplies: 4Last Post: 12-02-2010, 11:11 AM -
Stepper motor help
By Mucky Mike in forum Stepper & Servo MotorsReplies: 2Last Post: 04-04-2009, 04:25 AM
