03-07-2019 #1
Hello everybody!
Does anybody have an experience with high speed spindles (35000-45000rpm) for chipboard cutting?
We want to change our 18000rpm 7,5kw spindle and replace with a new one (42000rpm 10kw) to increase our CNC router cutting speed.
And here we have a lot of questions in our heads: maybe chipboard at such high speed cutting gets burned edges? Is it possible to use diamond cutters? and so on...
It would really appreciate if somebody could share his/her own experience. What do You think of this idea ( more rpm= higher cutting speed) in general ?
Thanks in advance!
05-07-2019 #2
Don't have exact experience with this, but normally it's not the spindle, it's the router bit.
Questions should be what exact router bit and how much does it cost? a "normal" PCD diamond bits is around 250-300 euro and 18k rpm.
I cut laminate using CMT insert bits at 50 euro the bit and very cheap inserts. I believe this is the best normal bit for this job.
Where did you see a router bit for cutting laminate at 40k RPM and a PCD at same time?????
PS. If you have the guts to use 700e-1000e router bit, thats probably the best for your job https://www.mobiltecnica.com/es/cabe...ra-ensambles_1Last edited by Boyan Silyavski; 05-07-2019 at 06:26 PM.
10-07-2019 #3
Hello Boyan,
Thank you very much for your replay...
Actually it was one of the questions in our heads. But we found some producers in the China who declaring what they produce bits for such high speed rotations. And prices are really acceptable. Next week our colleagues in China would make some test with them... After reviews, I would place some comments here...
10-07-2019 #4
Chinese make nice stuff, cheap stuff but its a copy stuff. If CMT and Onsrud dont have cutters That can do that, i dont see how the Chinese would have.
I looked now in Onsrud catalogue and see they have a so called High velocity bit. So from tables i see that you can go as far as 0.6mm per tooth. So if you spin that cutter at 40k your machine will have to move with 75m/min.
So upping the spindle speed does not seem the solution for me.
How deep you are cutting normally???
From my calculations you should be able to slot cut Hard Plywood using 16mm indexed bit at 10mm deep at 18k spindle and 7500mm/min feed. That needs |~ 6.6kw power , and if you upgrade spindle will be able to do same at 15mm depth. Tool stick out 40mm and 20mm flute.
10-07-2019 #5
Is you're machine capable of cutting at 40m-50m/min? And holding parts down at those speeds? If not, the higher RPM will be of no benefit.
An 18,000 rpm spindle can easily cut at 30m/min with a 3 flute compression bit.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
11-07-2019 #6
Exactly, thats what i meant. You said it better. But still 3kw more, according to my calculations will be aproximately 30% faster / or deeper/ so if in a production maybe its worth. But as you say, they will have to be able to hold it down properly, so its the setup... I believe these types of spindles are meant to go on machines that are able to auto feed the sheets and auto evacuate them from table to next stage. The whole chain of production must be fast
30-07-2019 #7
Thanks guys for your posts...
And sorry about delay with my answers, was out of office few weeks...
I think my problem is: I have not explained situation how we work...
We are furniture producers. Each day we cut approx 50 laminated chipboard sheets (around 3-5km long cutting way per day)
Yes, with one thing I agree, with expensive bits is possible to reach 22m/min. and more. If you are on MDF cutting daily... Unfortunely, we using MDF boards really rare. If you cutting laminated chipboard, is absolute nonsense to use expensive bits. They loose sharpness very quick. In that case we buy cheap Chinese bits and after just throw them away... But with cheap Chinese bit you never reach speed more as 9m/min. Our partners have 24000rpm. And they are able with same bits to cut approx 20% faster as our 18000rpm...
That is point about idea to increase rotation speed. For me is logical: more rpm=more working speed.
We need to increase our production speed. We have a choice to buy another faster spindle or enter the second shift. For third CNC router we have no place available...
sincerely
31-07-2019 #8
01-08-2019 #9
When you say "laminated chipboard", what is the laminate? Is it a plastic laminate, or a melamine paper laminate?
Plastic laminate is very abrasive. If you are cutting a lot of plastic laminate, you should probably be using diamond bits. Cheap diamond bits are under $200 US, but should last for 400 sheets or more.
If you are cutting melamine sheets, good quality carbide bits are about $90-$130, and are good for about 100-125 sheets.
But you can get them sharpened about 3 times, for about $25 each. This works out to about $0.25 per sheet over the life of the tool.
If your bits are getting dull quickly, there's a good chance that you just aren't cutting fast enough. Doubling the feedrate will typically double your tool life, if RPM remains the same.
Try something like these:
https://www.onsrud.com/Series/60-100MW.asp
https://www.onsrud.com/Series/60-100MC.aspGerry
27-12-2019 #10
For laminated chipboard cutting, I usually run at 18000-24000rpm, feeding rate 10-15 meters/min.
I am using Tiger T011 compression TCT bits, and it can cut 100 piece 1.2m x 2.44m laminated chipboard, but can not be resharpened.
It helps me save a lot.
There are currently 13 users browsing this thread. (0 members and 13 guests)
Chinese ATC spindles
By Voicecoil in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 29-10-2018, 10:37 AM -
Cutting Melamine faced chipboard
By NPW_BESPOKE in forum Machine DiscussionReplies: 9Last Post: 16-01-2018, 12:54 PM -
working with only low grade chipboard
By steven in forum Woodwork DiscussionReplies: 0Last Post: 28-11-2015, 12:33 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM -
NEW MEMBER: Spindles
By Johnp in forum New Member IntroductionsReplies: 4Last Post: 28-06-2009, 11:46 AM
