Page 2 of 2 FirstFirst 12
    Are all the axis free? no binding ?
    John S -
    jonm's Avatar
    Location unknown. Last Activity: 19-06-2011 Has been a member for 9-10 years. Has a total post count of 89.
    yes john everything seems free without the screws attached light finger pressure will move them
    It is the velocity and acceleration figures that adjust the speed, what are they set to?
    jonm's Avatar
    i have tried various settings in here
  5. #15
    Right the maximum you can do with this is 177.18mm / min if it can get up to speed in time hence your 88mm/min or suchlike.
    Leave the steps alone and increase the velocity to 2,000 to start and acceleration to about 150 as a start point.
    John S -
  6. #16
    jonm's Avatar
    thanks john
    so my steps are set right , will try the settings you suggest, i knew i should be able to get a bit more speed somehow, if i can even get to 1000mm a min i will be happy
  7. #17
    jonm's Avatar
    managed to get my speed up , wired the steppers bipolar single coil
    at 2.5 amps the 3nm motors are down to about 2nm but the speed has increased quite considerably can get about over 1000mm/min
  8. #18
    If you increase speed, then the torque will inevitably go down.
    What was the problem?
    (Glad you got it sorted!)
  1. Need to slow down a signal due to Safe Torque Off alarm
    By corkcnc in forum General Electronics
    Last Post: 04-06-2014, 11:35 PM
  2. Machine Slow on Curves
    By swisscheese in forum Computer Software
    Last Post: 12-04-2014, 12:49 AM
  3. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  4. Help! Steppers losing steps and making a racket under slow feed..
    By fasteddy in forum Stepper & Servo Motors
    Last Post: 06-08-2011, 03:03 PM
  5. Forum Slow
    By pcstru in forum General Discussion
    Last Post: 27-01-2011, 03:54 PM
