Thread: best stepper driver???????
26-03-2013 #28
Shouldn't be taken into account the motor amps/torque vs. the machine weight/working material?
If I put 3A motors on a belt driven PCB milling machine it is impossible to use that power assuming to have idle-current reduction.
I think the 60% rule for the power supply works only with toroidal transformers which have an instantaneous power at least 25% higher than the nominal, and with one PSU for all motors because it is unlikely to have all axis under high loads at the same time.
John, what rated current had the motors and drives for your conversion where you used reliably a 400VA transformer?
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper Driver requirements?
By Dwayne Dibbley in forum Motor Drivers & ControllersReplies: 3Last Post: 24-07-2013, 05:29 PM -
stepper driver tester
By ptjw7uk in forum Motor Drivers & ControllersReplies: 2Last Post: 24-06-2013, 05:48 PM -
Which stepper driver
By Colin Barron in forum Motor Drivers & ControllersReplies: 0Last Post: 25-09-2010, 08:33 PM -
connecting stepper driver to PC
By berkut in forum General ElectronicsReplies: 2Last Post: 10-06-2009, 09:25 PM
