Page 1 of 4 123 ... LastLast
    Hi All
    Big question I know,but just wondered what every one is using.
    I had hoped to modify an old driver board but that went up in smoke tonite, which has shown me how difficult it is to fault find on a single board and has put me off getting one of the "all in one boards" from china
    I need 3 axis to drive 2 phase bipolar motors wired in parallel at 2 amp per phase, any ideas?
    I use Motion Control Products MSD542 drives. They have worked fine for around a year now.
    http://www.motioncontrolproducts.co....&products_id=3
    Arc sells the same driver cheaper and it includes VAT.
    http://www.arceurotrade.co.uk/Catalo...tepper-Drivers
    John S -
    Lee Roberts's Avatar
    Lives in Milton Keynes, United Kingdom. Current Activity: Viewing Admin Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,976. Received thanks 239 times, giving thanks to others 807 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    Are they the same driver John ? or the PM range ?
    i'm using MSD542 as well, i'v used the routoutcnc drivers as well.
    NB70's Avatar
    Lives in Swansea, United Kingdom. Last Activity: 02-07-2025 Has been a member for 9-10 years. Has a total post count of 61. Received thanks 10 times, giving thanks to others 9 times.
    I use the Motion Control Products MSD542 ones, I think they are made by Leadshine in China (M542 OEM model) and sold under different brandnames
    Leadshine m542
  6. They are not the same driver, close but not the same.
    As allways in china you will find copies of everything.
    Leadshine are the largest manufacture of stepper drivers in china, and there are lots of copies of their drivers, some good, some not.
    by the way i will match Arc euro trade prices as long as i have them in stock.
    You may also want to try our PM752 for higher current motors, it is a very good driver and goes all the way up to 70V.
  7. Actually they may be the same, after looking at their webpage.
    Now you tell me......:heehee:
    I've decided to roll my own, with the help of Tribbles of course. 4amp, idle current reduction and full power on half step but no micro stepping.
    If it dosnt work out then £30-40 an axis sounds great
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Hi Lee,
    My all in one packed up ages ago, and put me off finishing my machine. I have decided to give it another go now. All I am missing is the motor drivers. Do these boards work with Probotix H23 - 400 4 wire motors ?. Thats all the info on the motors. I didnt buy them myself.
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
    Hi Lee,
    What ones? Can you not email them and get the spec sheet for the motor, i found the 8 wire version: HT23-400-8.pdf, most drivers will run motors but you want to match them really.
    .Me
  1. Replies: 1
  2. Stepper Driver requirements?
    By Dwayne Dibbley in forum Motor Drivers & Controllers
    Last Post: 24-07-2013, 05:29 PM
  3. stepper driver tester
    By ptjw7uk in forum Motor Drivers & Controllers
    Last Post: 24-06-2013, 05:48 PM
  4. Which stepper driver
    By Colin Barron in forum Motor Drivers & Controllers
    Last Post: 25-09-2010, 08:33 PM
  5. connecting stepper driver to PC
    By berkut in forum General Electronics
    Last Post: 10-06-2009, 09:25 PM
