Thread: Mach3/Linuxcnc
02-08-2020 #1
Hell
I have a Routout CNC router which I've been using with Linuxcnc for a number of years. I have an old PC with a parallel port and I'm happy with linuxcnc and familiar with it.
I've now bought a mill which has been set up to use Mach 3 (through a USB cable). I don't have Mach 3. How easy would it be to use linuxcnc on this? To state the obvious, this is not exactly the often-asked question about whether you can use linuxcnc on a computer with only a USB port ( know you can't). I already have the parallel port, I need a way of translating the parallel port's output into a USB format, if this is possible.
No you cannot use USB to control linuxcnc. But depending on the mill you could just use a simple Chinese BOB connected the the P/port.
You could even use the same PC as the router but not at the same time. ie. you can have two different configs one for the router and the other for the mill
It would help if you could give more info and pics of the mill. What version of Lcnc are you using?..Clive
02-08-2020 #3
Thanks - I'm away from home at the moment so can't give those details. I think it may even be EMC rather than linuxcnc. TBH I understand so little of Linux (in this case Ubuntu) that I have barely touched the configuration since I bought the whole set-up second hand a few years ago.
What should I be searching for with a BOB?
02-08-2020 #4
Something like this https://www.ebay.co.uk/itm/5-axis-CN....c100667.m2042
New to LinuxCNC - Trying to add a PPort card and get LinuxCNC to start
By TnW in forum LinuxCNC (EMC)Replies: 12Last Post: 24-04-2020, 11:01 AM -
NEW MEMBER: LinuxCNC using EtherCAT anyone doing this?
By Brassneck in forum New Member IntroductionsReplies: 1Last Post: 01-08-2019, 11:12 AM -
What do I need to run LinuxCNC???
By gatesy in forum LinuxCNC (EMC)Replies: 22Last Post: 02-12-2015, 07:42 PM -
Mach3 vs LinuxCNC/EMC What do you use and why?
By Lee Roberts in forum Machine Control SoftwareReplies: 46Last Post: 26-11-2013, 01:02 AM -
How many LinuxCNC/EMC users do we have?
By birchy in forum LinuxCNC (EMC)Replies: 16Last Post: 30-12-2012, 08:08 PM
