    The mill is quite small and compact and has had an enclosure built to contain a coolant system.
    Its dimensions are 1500mm x 1500mm x 1800mm, weight estimated to be 750kg,it will fit neater into a corner as its actually T shaped.
    The mill is running Linuxcnc/pathpilot. The original parts are being sent with the machine should someone at a later date wish to put the mill back to its original manual machine configuration and include the planer and multi axis head attachments.
    MT3 tooling, manuals/documentation and spares included. It has been and still is a much loved little machine. An attempt was made at building a power drawbar and a 4th axis sadly project are not quite complete, needs some tlc. However the control cabinet has been wired to operate the 4th axis
    The mill has a 3 phase inverter for the 2.2 kw spindle motor fitted and runs from a single 220v socket. The spindle is an MT3 taper and runs up to 7000 rpm.
    Sold
  1. elliott omnimill convert to cnc ?
    By mcmental76 in forum Milling Machines, Builds & Conversions
    Last Post: 10-07-2020, 08:34 PM
  2. Wanted - XY yoke (dogbone) for 1955 Series 1 bridgeport knee mill
    By V8kid in forum Bridgeport Milling Machines
    Last Post: 17-04-2020, 05:18 PM
  3. Beaver Knee mill conversion- by a newbie
    By ukmxer in forum Milling Machines, Builds & Conversions
    Last Post: 11-02-2018, 03:39 PM
  4. Replies: 0
    Last Post: 07-01-2017, 01:36 PM
  5. Elliott 00 onmimill
    By Richard in forum Milling Machines, Builds & Conversions
    Last Post: 08-03-2015, 11:09 PM
