    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 280. Received thanks 2 times, giving thanks to others 69 times.
    So I have a piece of 20mm thick 6068 aluminium (400x300) .
    I know I can create holding tabs in cambam when profiling.
    Instead of cutting around a piece via profile, I am pocketing around the outside of the piece to be less harsh on the 6mm single flute endmill (although it will have a lot more material to mill) and also I will get much less vibration . I’d like to know if there is a way in cambam to avoid areas while pocketing to avoid clamping areas ? Then I can move the clamps once done to finish.
    dudz's Avatar
    Ok. Found a solution. By creating an island . It will avoid these areas
  1. cnc router x axis starting before y axis finished when pocketing ?
    By Robin Oakapple in forum General Discussion
    Last Post: 30-08-2020, 11:09 AM
  2. Trying to fathom cambam
    By John11668 in forum General Discussion
    Last Post: 09-07-2020, 09:09 PM
  3. CamBam / FreeCAD 2D/3D MOP question Please help
    By dudz in forum CAD & CAM Software
    Last Post: 30-08-2014, 09:11 PM
  4. Some general questions. Drilling and pocketing.
    By Wal in forum Metalwork Discussion
    Last Post: 15-02-2014, 12:05 AM
  5. Mach3 / cambam
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 01-04-2013, 06:02 PM
