Thread: Rotary Table CNCing
06-01-2010 #12
As I said I managed to machine to the inside of the offset to accept a needle thrust bearing and then realised that there would be no support at that end so I inserted a sintered bush and reamed to size on the outside a normal ball thrust could be used as there is more room.
There were several momenst during the whole thing where I thought I had taken on more than I could do with my limited skill set. I also ended up with several bearing revisions as the whole thing was designed from bad idea to bad idea, if I had to do it again I would just buy a Arc euro(John S) finished one!
Peter
Diy 4th axis rotary table using 100mm chuck with minimal backlash
By kingcreaky in forum Linear & Rotary MotionReplies: 3Last Post: 05-09-2013, 01:03 PM -
CNC Rotary table/lathe head indexing
By Kwackers in forum Electronic Project BuildingReplies: 40Last Post: 09-12-2011, 03:33 PM -
Which chuck to fit 6" rotary table??
By wiatroda in forum General DiscussionReplies: 19Last Post: 10-08-2011, 08:47 AM -
Mounting a chuck on a Rotary table
By irving2008 in forum Machine DiscussionReplies: 17Last Post: 02-09-2010, 07:23 PM -
Setting up work on the rotary table
By irving2008 in forum Machine DiscussionReplies: 6Last Post: 09-01-2010, 10:27 AM
