    I have a 6040 cnc machine. but no controller. That is no box, or any parts. I need to buy one that I can plug in to the 240 power, attach XYZ to machine, and run 3 axis machine with 1500 router. I want to purchase the complete box. Hopefully full price under $600 Australian. Preference not Mach 3 or 4, Would appreciate advice Norman
    Lives in East Lothian, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,988. Received thanks 373 times, giving thanks to others 9 times.
    If you want to avoid Mach, then I'd doubt that there is anything available ready to go, and something custom built by somebody else is likely to cost more than $600.
    Hey @Norman welcome to the community and thanks for joining!
    Your budget’s definitely tight for a full plug-and-play controller setup that isn’t Mach-based, but not impossible.
    If you're looking to avoid Mach 3/4, I'd suggest looking into GRBL, Masso, or even Centroid Acorn, but do note:
    GRBL-based boxes (like the OpenBuilds BlackBox or similar) can be relatively affordable, they are easy to set up really and often support G-code sending from something like UGS or CNCjs (browser-based interface, real-time control). They’ll typically run on 24V, so you’d need compatible stepper drivers or an integrated board.
    Masso is more expensive and probably outside your budget to be fair, but it’s a great standalone controller with no PC needed.
    Centroid Acorn is a solid, Windows-based controller with a tidy interface and support, but again, it’ll push you closer to the top end of your budget once you factor in a power supply and enclosure ?
    If you want to stay under $600 Aussie (about £300 GBP for our shores), your best shot is then a GRBL or Mach-compatible controller from AliExpress and/or Amazon, but be very careful with the specs, a lot of them are cheap but poorly made.
    Run specific units via the marketplace sub forum if un sure
    Let us know what steppers you’re running (NEMA23? 34?) and if you already have drivers, what they are too, that can help narrow down options.
  5. The Following User Says Thank You to Lee Roberts For This Useful Post:
  1. What controller would you recomend?????
    By ravihotwok in forum Control Hardware & Systems
    Last Post: 06-12-2024, 08:28 AM
  2. CNC controller
    By clivemgriffiths in forum Chinese Machines
    Last Post: 30-12-2021, 04:06 PM
  3. Usb controller
    By pemmott in forum Artsoft Mach (3 & 4)
    Last Post: 02-12-2019, 07:34 PM
  4. In need of help with controller software
    By joss01 in forum Machine Control Software
    Last Post: 08-10-2018, 07:07 PM
  5. Controller Box
    By M250cnc in forum Motor Drivers & Controllers
    Last Post: 21-11-2010, 01:34 AM
