    Hello.
    Seeing your works (you have made masterpieces) I wanted to upload some of my works from the past.
    There are 2 bases for walnut wood tealights in the style of a chalice, one round and the other hexagonal, varnished.
    I should point out that both the candlestick and the ring are made of a single piece of wood.
    Because I like it a lot and also because of the difficulties I encountered, I have put it as an avatar on the forum.
    I hope you like them.
    EDIT: Photo's added to post by Lee.
    "I apologize, but I am unable to upload images due to technical difficulties with the forum. I hope this will be resolved shortly."
ID:	32755   Click image for larger version.
ID:	32756   Click image for larger version.
ID:	32758   Click image for larger version.
ID:	32759   Click image for larger version.
ID:	32757   Click image for larger version.
    @NikosR
    If you would like to email them to me, I can upload them for you and attach to your posts ?
    [email protected] is my email address :)
  4. The Following User Says Thank You to Lee Roberts For This Useful Post:
  5. #4
    Hi Nikos,
    I have attached your photos for your last post for you, your work looks great thanks for sharing. Attached is some MDF items i made last year, the BMW is 6ft long and now hangs in a car show room in Los Angeles. I used a French cleat design for the hanging mechanism.
    P.S The Aston Martin wording is single 3mm MDF letters, I mastered the fit so they could be inserted into the green section once painted seamlessly...
    Translation:
    Έχω επισυνάψει τις φωτογραφίες σου για την τελευταία σου ανάρτηση, η δουλειά σου φαίνεται υπέροχη, ευχαριστώ που την μοιράστηκες. Επισυνάπτω μερικά αντικείμενα από MDF που έφτιαξα πέρυσι. Η BMW έχει μήκος 1,80 μέτρα και τώρα κρέμεται σε μια έκθεση αυτοκινήτων στο Λος Άντζελες. Χρησιμοποίησα ένα γαλλικό σχέδιο με τάπες για τον μηχανισμό ανάρτησης.
    Υ.Γ. Η επιγραφή της Aston Martin είναι μεμονωμένα γράμματα από MDF 3 χιλιοστών, κατάφερα να τα εφαρμόσω τέλεια ώστε να μπορούν να εισαχθούν στο πράσινο τμήμα μόλις βαφτούν άψογα...
Name:	1 -etsy.jpg
ID:	32762   Click image for larger version.
ID:	32763   Click image for larger version.
Name:	2 - etsy.jpg
ID:	32761   Click image for larger version.
ID:	32764   Click image for larger version.
ID:	32765   Click image for larger version.
ID:	32775   Click image for larger version.
Name:	1 - etsy.jpg
ID:	32766   Click image for larger version.
Name:	2 - etsy.jpg
ID:	32767   Click image for larger version.
Name:	3 - etsy.jpg
ID:	32768   Click image for larger version.
Name:	3 - etsy.jpg
Name:	1 - etsy.jpg
ID:	32770   Click image for larger version.
ID:	32771   Click image for larger version.
ID:	32772   Click image for larger version.
Name:	1 - etsy.jpg
ID:	32773   Click image for larger version.
ID:	32774   Click image for larger version.
ID:	32776   Click image for larger version.
Name:	3 - etsy.jpg
ID:	32777   Click image for larger version.
Name:	6 - etsy.jpg
  6. The Following User Says Thank You to Lee Roberts For This Useful Post:
  7. #5
    LEE What end mill did you use to cut the 'Aston Martin' letters, and did you use the same one for the pocket on the green surface?
There are currently 18 users browsing this thread. (0 members and 18 guests)
  1. Wooden sunglasses
    By jimkrum in forum Woodworking Project Showcase
    Last Post: 19-02-2026, 04:56 PM
  2. Replies: 14
    Last Post: 31-01-2020, 04:02 PM
  3. My first Wooden Toys
    By davidcha in forum Woodworking Project Showcase
    Last Post: 21-02-2019, 02:38 AM
  4. Wooden CNC
    By Andyshomecrafts in forum Gantry/Router Machines & Building
    Last Post: 10-08-2015, 11:54 PM
  5. wooden joints
    By luke11cnc in forum Woodwork Discussion
    Last Post: 18-10-2012, 11:59 PM
