Page 2 of 2 FirstFirst 12
    One trick you can do with torroids is to wind about 30 to 40 turns of the same gauge wire over the top of what is already there.
    Switch on and test this winding and you will get around 10 to 18 volts, depends on number of turns.
    Now if you connect this to the ends of your original winding then rectify you will get either 82.5 volts plus the extra or minus depending on how you connect the extra coil up.
    You then need to play around with the number of turns to get what you need, it can be worked out by voltage divided by number of turns.
    Also very handy to get an extra 5 v or 12 v supply for logic circuits out of a stock transformer.
    Once tested a few turns of fabric tape around the torroid will tidy it up fine.
    John S.
  2. Thats exactly what I did John, had a 0-50,0-50 10A toroidal, wound 10 turns of wire round it (keeping them spaced evenly), measured the volts given then adjusted the turns to provide a nice 8v DC for the 5v regulator.
    Note: If you are using John's idea in a 'buck' (reduction) arrangement you should measure the output volts when on load to avoid it not dropping as much or more than expected. Else assume a 5% regulation. So for a 70v DC output you need a 50v AC, if you have a 55vAC toroid it may drop to 52.5vAC on load so if you buck 5v you may only have 47.5v AC (67v DC) on full load. You may only want to buck 3.5v - depends on what compromise you decide.
    Guys, can you have a look at this post please:
    Link: http://www.mycncuk.com/forums/showthread.php?t=462
    .Me
    Any progress on this Son of a Beast ?
    .Me
  5. #15
    Lives in East Lothian, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,911. Received thanks 360 times, giving thanks to others 8 times.
    Not much.
    Got a 50V toroid and tested it a while back, which gave a nice 75Vdc when I tested it.
    Bought a metal cabinet to house all the electrics, but it's still sitting in it's packaging.
    Been too cold outside to do much, plus what time has been spent outside has been on a couple other ongoing projects.
    Hopefully get back to this next month.
  6. #16
    I presume this conversion died?
    I know this is an ancient thread to drag back from the dead but I'm converting a Harrison Milling machine myself and just wondered if it got any further than the last update or if that was it?
  7. #17
    Take a look here if you haven't already - a very tidy Harrison conversion. Pics and videos of finished job on the last page of that thread.
  8. #18
    Well and truly dead!
    I realised just how much of a pain doing a good manual to CNC conversion really is, sold this machine, and bought a bigger barebones already CNC'd knee mill, although progress on that has been very slow, as other projects keep getting in the way, and I keep dithering over the tool changer.
  9. #19
    Quote Originally Posted by bikepete View Post
    Haha, I've known Andy for many years and it's his fault I'm doing a Harrison in the first place (that and I already have a Harrison Lathe). :) Mine is not going to be as neat as his though. Mostly because he used driven nuts for Z and X and I'm just going to hang the motors in the breeze and spin the ballscrews.
    Figured as much but nice to have closure. :)
  1. CONVERSION: Sx3 mill conversion
    By dazza in forum Conversion Build Logs
    Last Post: 29-04-2014, 10:23 AM
  2. NEW MEMBER: Saying hello, about to start a mill conversion.
    By irgonomics in forum New Member Introductions
    Last Post: 28-04-2013, 03:35 PM
  3. CONVERSION: My Sherline Mill Conversion videos
    By panofish in forum Conversion Build Logs
    Last Post: 06-05-2012, 07:13 AM
  4. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
  5. Help with drill-Mill conversion
    By Ross77 in forum Milling Machines, Builds & Conversions
    Last Post: 02-04-2010, 10:25 AM
