12-03-2012 #91
Before I forget yet again, a public thank you to JohnS for the loan of a single speed Kress (he also machined up a collar to make it fit inside the original motor clamp) allowing us to carry on machining!
12-03-2012 #92
12-03-2012 #93
Today I've received the replacement spindle from the ebay seller love-happyshopping, it doesn't seem new but at least works, I hope it will last more than the first one... Anyway I'll probably buy a kress spindle.
19-03-2012 #94
Just to add to the FAQ ;-)
Spec on the spindle supplied:
https://sites.google.com/site/cncdiyorg/e240-spindle
Adam
The Following User Says Thank You to Musht For This Useful Post:
10-04-2012 #95
Well surprise surprise...yet another issue....y axis now misbehaving....similar to z axis problem so guessing that yet another cable needs replacing!! ho hum!
Edit: Yep replaced cable...now running ok again...PITA!!!Last edited by camhguh; 12-04-2012 at 12:46 AM.
11-04-2012 #96
can anyone suggest a good, reliable company that sells cnc routers in China?
11-04-2012 #97
24-04-2012 #98
24-04-2012 #99
Finish looks respectable on the flat, but a little rough on the sides?
Looks like a 2flute HSS cutter? What diameter, spindle speed, feedrate, depth of cut and stepover did you use out of interest?
My machine is currently running cutting a huge aluminium sheet at 780mm/min with an 8mm single flute carbide at 2mm depth of cut. It's been going for hours at that...
24-04-2012 #100
Chinese Nema 34 packages on ebay
By adamh in forum Marketplace DiscussionReplies: 4Last Post: 06-12-2013, 12:24 PM -
Chinese CNC machines - Request
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 03-05-2012, 05:55 PM -
NEW MEMBER: Just purchased Hardinge HL TFB tucson arizona usa
By jimbocafe in forum New Member IntroductionsReplies: 1Last Post: 19-12-2010, 02:45 PM -
Used Routout CNC Recently?
By CraftyGeek in forum General DiscussionReplies: 1Last Post: 17-07-2010, 12:37 PM -
Purchased a Taig CNC Micromill from Ebay
By alan2525 in forum Marketplace DiscussionReplies: 10Last Post: 16-04-2010, 10:53 AM
