Thread: DIY spindle design
27-07-2009 #21
Forgive me if this question is off topic.
Jeremy, that is a great piece of work.
You mentioned that you used the Shumaker suggested servo tester to get the pulses needed to get the motor going.
My question is: Does anyone have experience of driving this type of motor control from the MACH3 software suite?
I know from reading the MACH3 manual that PWM speed control is covered on page 5-7 & 5-17, but has anyone actually done it with a DC brushless motor?
Here's hoping!!
JohnTemplecorran
Where the Light was kept during the Dark Ages
30-07-2009 #22
Sorry, I just thought to ask you if you have had any machine time with this new spindle yet?
Most important to me is: how noisy is it?
cheers
JohnTemplecorran
23-11-2009 #23
Hi Jeremy,
I've just set up an X1 mill with DIYCNC gear. I'm now looking at building a 1mtr x 0.75mtr router. It's been sometime since you made your brushless spindle, I wonder how it's performing? I wondered about using a watercooled esc if heat was a problem.
Very useful thread.
Chris
23-02-2011 #24
This is very interesting. I've already constructed a gantry type mill and am using a Kress router to mill non-metals. I'm now looking at ways of milling non-ferrous metals and manufacturing a spindle motor for this purpose. One component of the spindle I'm having difficulty sourcing is the actual spindle/collet holder - from where did you get yours please. I've sourced a suitable motor and have decided upon a step-pulley belt drive system in order to achieve good torque at low speeds.
23-02-2011 #25
Hi miopicman , has Jeremy used an air die-grinder as a base for his spindle?
http://www.screwfix.com/prods/38706/...ir-Die-Grinder
Chris
23-02-2011 #26
ER11 C8 100mm straight shaft ebay... 8mm shaft (good for mounting straight through a sutable brushless motor)
C10 10mm shafts are like rocking horse s**t
C12 12mm shafts are more common
23-02-2011 #27
I don't think so; have a look at this: http://www.screwfix.com/sfd/i/cat/pdfs/89/p4764389.pdf
30-05-2012 #28
anyone have videos of these diy spindles cutting aluminum ??
30-05-2012 #29
The Following User Says Thank You to blackburn mark For This Useful Post:
30-05-2012 #30
There are currently 11 users browsing this thread. (0 members and 11 guests)
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Design help etc required with DIY CNC Router Design / Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 21-10-2011, 04:50 PM -
My spindle design
By Ross77 in forum Tool & Tooling TechnologyReplies: 22Last Post: 06-08-2010, 06:03 PM
