Thread: operation cnc
Page 17 of 18 FirstFirst ... 715161718 LastLast
  1. #161
    if you ever struggle to think of electronics and need to use examples always use water... it's far easier.
    i.e. example 1 you have 1 hose pipe(outgoing signal) with a splitter in the end to make 2 outlets (2xsteppers)... water reaches the splitter and splits equally between the 2(both steppers get the same signal)
    example 2 you have 2 hose pipes connected straight to 2 outlets and the flow of these is restricted by a computer, something goes wrong with the first outlet and the flow is slightly restricted at the wrong time compared to outlet 2.. you now have one pipe pouring more water than the other (one stepper moving out of sync to the other.
    it's just limiting the possibilities of things going wrong. i understand what jazz is on about and i "go way back" with computers
  2. #162
    D.C.'s Avatar
    Quote Originally Posted by wilfy View Post
    except this is a false analogy.
    If you 'go way back' with computers and understand what you are talking about perhaps you can explain what is wrong with what either I or Jon said in this very specific instance.
    Does a piece of software running on a computer have magical pixie hero men inside of it that create a 'magical physical hardware' perfect connection between the software and the cnc machine or does a computer use a piece of software (often called a driver) to decide in 'software' which signals to send to which lumps of metal?
    If 'hardware' is somehow so much reliable than 'software' and desirable perhaps you could explain why mission critical systems use ECC ram, or why we need transactionable databases or why TCP has to sit on top of IP?
  3. #163
    if you search for 2.2kw spindle on ebay... you will notice they are all portsmouth based suppliers. It appears there are multiple suppliers but Im sure its just one place selling them.
    Over the course of the past 4 days, I have messages 7 individual suppliers. asking them to confirm they have stock, are they shipping from the uk I have recieved NO responses.
    Most of them are 'make an offer' so ive tried making an offer say a tenner below the asking price, again NO responses.
    You will notice that essentially the price is £252, some of them are a straght 252, some of them are £162.00 with 90 postage and all the variations under the sun. However I just cant get a response from them so im hardly willing to send them money.
    Which leaves me with cnc4you.. who are offering a bargain price of £369 however they are uk based and offering a direct warranty
    or Chai has quoted me in his "best price" kinda way £310 plus £60 postage
    are there any other options? ive googled 2.2kw spindle with not much luck... thought id check with you lot before I order
    Matt
  4. #164
    Matt, I suspect your right about the one seller using multiple ebay names, has been mentioned before either on this forum or another. Lack of a reply may be down to them being away at the moment. Apparently it's the Chinese Spring festival at the moment, I was looking for a cooling pump for a 2.2kw spindle & tried searching ebay for the one Robin suggested. Found a seller on the uk site (Chinese) who had a message saying he was closed from 7th to 17th feb for this festival.
  5. The Following User Says Thank You to martin54 For This Useful Post:
  6. #165
    D.C.'s Avatar
    Sorry about the thread hijack and congrats on the progress btw.
    martin is right, it is chinese new year which these days is apparenty the largest migration event in human history, hundreds of millions people moving from the cities back to their home villages to spend two weeks with the family. Give them a couple of weeks and it they will be back to business as usual.
    Edit: On the plus side if you can find guys still trading as normal delivery times seem very impressive, two orders I placed for electronics stuff with bog standard freebie China post arrived in 4 days and 6 days. (Real days not working days)
  7. #166
    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    D.C. in theory, everything should work, but in practice, things may not work quite right. It can be things like marginally different speeds between a pin switching high and low, which are then exaggerated by drives that respond slight differently to high/low inputs and/or slight lag due to the different switching speeds. However with modern drives, it's pretty much a non-issue, but why take the chance?
    Personally, given the choice of doing something in hardware or software, I'd personally do it in hardware every time, as it helps eliminate potential issues.
  8. #167
    If it works in theory but not in practice, that just means your theory wasn't good enough.
    Again, the answer is vague so I'll repeat what D.C. asked - what specifically is the problem? The timing delays you're talking about are completely negligible, so there is no potential issue to eliminate. Originally the question was if you should set the motor directions in software, or one of the motor phases round to invert the direction. There will not be any tangible difference between the two, unless the software is pathetic.
  9. #168
    Jonathon, go and search the Mach Yahoo group for Art's posts about the intracies of parallel port timing, because I'm beginning to understand why Jazz gets so pissed of with you.
  10. #169
    D.C.'s Avatar
    Interesting, I would trust 'software' over 'hardware' everytime. I tend to see hardware as crap and dumb , you send a bunch of electrons down the wire and pray they get to their destination (why do we need shielded cable again?) when you add a bit of intelligence into the equation you can account for and correct errors, hence why people looking for better precision use closed loop steppers and absolute positioning systems to catch and correct the all the errors produced by the hardware.
    Without the ability to fix all the hardware issues using cleverness the internet would be stuck in the telegraph age. :(
  11. #170
    DC, I'd rather trust hardware, as hardware being dumb, should always do the same thing.
    It's a bit like do you swap a motor phase on a VFD, or do you just change the setting in the VFD to change normal motor direction?
    Both should work...
  2. clunks / missing steps - DM856 and single pulse operation
    By dsc in forum Motor Drivers & Controllers
    Last Post: 09-12-2013, 02:22 PM
  3. screening / glitchy operation - sanity check
    By dsc in forum General Electronics
    Last Post: 01-12-2013, 11:35 PM
  4. CNC3040 erratic stepper motor operation (fixed)
    By DanielF in forum Motor Drivers & Controllers
    Last Post: 30-12-2012, 07:52 AM
  5. BUILD LOG: Operation Clueless, CNCRP 4848 Build Log Eventually.
    By BedlamRik in forum DIY Router Build Logs
    Last Post: 28-12-2012, 12:39 AM
