Thread: 3 axis cnc/router bed
21-12-2012 #21
Ah ha.. probably these : x20 T-Nuts Slot 10 M6 1001 | eBay
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
3 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle..... CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
22-12-2012 #22
OK. These rails purchased...2 linear bearing slide unit SBR25-850mm rails+4 blocks | eBay
I hope the quality is as good as the ones sold in the UK.Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
22-12-2012 #23
You should have contacted Chai directly then you'd have got a better deal!!
Most of the rails sold in the UK are imported from China anyway ;)
28-12-2012 #24
Ok.... I received my Aluminium via UPS. 470mm X 300mm X25mm
I clamped it down to the original bent Vacuum bed (which temporarily straightened it)... planned the new supported rail bearing block mounting holes in CamBam and successfully drilled and counter-bored the holes. First thing I have ever done with this machine since changing the Z axis plate and adding the 2.2kw Chinese spindle. What an improvement so far !
Still a way to go to make it more sturdy, but I am already planning the next improvements to come.
Now... in respect of holes for clamps on the cutting bed.....For now I am going to drill and tap some holes for clamps. (maybe cutting slots later if needed). What size metric holes should I use for the clamps ? M4/M6 ?? and what depth ?Last edited by dudz; 28-12-2012 at 09:47 PM.
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
BUILD LOG: 3 Axis CNC router
By JoeHarris in forum DIY Router Build LogsReplies: 658Last Post: 21-06-2020, 10:41 PM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
