Threaded View
14-03-2016 #1
Getting near the end of my router/mini-mill build now and need to start looking at how to run jobs, i have a couple lined up already;)
I'm not new to milling - been running a Bridgeport for some years now, not new to CNC - been using a plasma table for a year now, so that should all help. I use SheetCam to produce my G-Code and I think I have it pretty much sussed for the mill now, just looking for tips.
This is the first job - pretty complex but what better way to learn;)
It's from 5mm 6061 Aluminium, has plenty of 3mm holes, slots, square features, its about 320mm long.
So far I am looking at using a 2mm carbide 2-flute cutter, mist coolant, I have figured out how to get sharp corners, also how to spiral-down to cut the holes.
Questions -
1 - I have used a calculator for feeds and got 24,000rpm, 487mm/min feed, 1mm DOC, these seem reasonable?
2 - I am unsure of DOC - this is input rather than output on the feed calculator - how do you know how much bite to take at one pass?
3 - Holding tabs to keep it together on the outside cuts, I'm guessing three or four, 0.5mm thick or less?
4 - Use the one cutter and go straight to dimension or split and do a roughing & finish passes?
5 - Use a bigger cutter for the roughing outside then switch to the 2mm for the finish?
6 - Features like the oval hole - leave it to fall out or use tabs again?
Any suggestions appreciated, I realise this is fairly adventurous but I would like to get these made in-house to increase my profit margin considerably ;)
There are currently 15 users browsing this thread. (0 members and 15 guests)
Beginner Moving Gantry Build? Read This!
By Tenson in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 23-05-2018, 05:30 PM -
Garage CNC - A gantry style machine design
By fandango in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 21-03-2014, 01:38 AM -
Truss style Gantry
By D.C. in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 15-12-2012, 07:23 PM -
A few questions to start a DIY mini CNC
By purple_rob in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 03-08-2009, 11:08 PM -
Vertical moving gantry????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 03-06-2009, 08:34 PM
