    what options are out there for 3d scanning an object and then turning that into some form of gcode for machining?
    its a subject I know nothing about but want to get into
    3d scanners are either extremely poor or exremely expensive at this point in time £5000 would get you a result worth machining £500 will get you something with very poor resolution not worth 3d printing let alone machining. A few cheap self builds around that can give results with a webcam and line lasers and get close to the sub £500 scanners, I have an £300 iSense sitting here that was a freebie thats good for displaying on screen with photo mapping but the resolution is so poor that its useless to produce a solid of any sort.
    Lives in Plymouth, United Kingdom. Last Activity: 21 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    There are also things like 123D Catch, a free online service, that will take a set of photographs of an object, taken from different positions, and turn them into a 3D model that can be given to a CAM programme to produce gcode. It does work, I have used it, but it doesn't work anything like as well or as easily as its documentation implies. Took me days to edit the STL 3D model data to get something usable. But in the end it did work. It's an option, and it might be better now than when I last used it (around a year ago).
    Came across the site below a while ago. Might be worth a look.
    http://www.david-3d.com/en/products/overview
    Hi Bud
    I have just purchased the Creality otter scanner and i really am impressed with it , not that i am an expert . far from it but i really am impressed with how fast it does a full scan
    pete
  1. RFQ: Aluminium machining
    By TadasM in forum Projects, Jobs & Requests
    Last Post: 07-02-2016, 01:54 PM
  2. aluminium machining
    By drumsticksplinter in forum Gantry/Router Machines & Building
    Last Post: 15-03-2013, 12:19 AM
  3. Machining Data
    By Rastanking in forum Computer Software
    Last Post: 24-04-2012, 04:33 PM
  4. Machining plastics
    By Web Goblin in forum General Discussion
    Last Post: 03-11-2011, 08:38 AM
  5. 3D scanning ?
    By Kammo1 in forum Probing, Digitizing & Scaning
    Last Post: 15-02-2010, 11:22 AM
