Thread: my build
  1. Quote Originally Posted by jonm View Post
    thanks irvine
    using 12 mm trapeziod .. would the 2 grub screws in the pillow block not hold the screw against any lateral movement .... can the bearing take axial load ,.. was looking for a way round this as i dont have a lathe
    Those type of bearings are poor at axial load, they can handle some but are not good for locating the shaft axially, which is what is needed to minimise backlash. Somewhere you need thrust bearings to take the axial load or angular contact bearings (hard to get in small diameter ID).
    jonm's Avatar
    Location unknown. Last Activity: 19-06-2011 Has been a member for 9-10 years. Has a total post count of 89.
    cheers kip
    good idea have some spare trapezioid will give it a go
    with the grinder
  3. Quote Originally Posted by Kip View Post
    Oh I dunno...it depends what load you're applying. For instance...I'm using pairs of common or garden 15 ID 35 OD bearings on my mini-router....zero backlash and well within their capabilities....For machining metals....AB bearings only for me. Horses for courses Irving...after all the MDF router will fall apart before the bearings reach their limit :naughty:
    Its not so much the bearings Kip, its the pillow block approach.. the way the bearing locates in the block doesnt give a positive position to the shaft. I'm sure it could be made to work for light cuts, but thats a fairly big router Jon's constructing so I'd assume he's got big plans for it ...
    For machining try a drill and an angle grinder equipped with a flap disc in combination with a jig.
    I accept no responsibility if you get whipped :D
    these are long lengths of TR12, going to need some bearing support on those just to stop the whip, and thats before you put any pressure on with the grinder...
  4. Quote Originally Posted by Kip View Post
    I have no bearing location on mine.....the bearings sit against Al plate as they have no radial loads....a spacer in the middle and a belleville washer and a bolt glued in....Nice glue though ;)
    I can't visualise this... picture needed...
    jonm's Avatar
    hi guys
    thanks for input ... fixed gantry to sides today, bottom runner in , all feels pretty rigid
    jonm's Avatar
    going to attempt to grind down screws to 8mm then use skate bearing .. with thrust bearing either side , on evilbay thrust bearings for £1.90 each
    cant find angular contact bearings at 8mm, and magneto bearings are £6 each ....... i am after all scotsman
    jonm's Avatar
    never mind.. soon be time to iron last years xmas wrapping paper....
    and tippex the cards..
    jonm's Avatar
    cheers kip
    bag of bearings arrived from " gap bearings " today...
    will feed three 12mm bearings on to trapeziod screw fix bearings down with theseClick image for larger version.
ID:	712 drill on one end , then attack with grinder... sounds so simple....... we will see
    Look for magneto bearings, they are the smaller versions of angular contact bearings
    John S -
