Page 1 of 18 12311 ... LastLast
  1. The latest upgrade to eMachineShop appears to have deleted the ability to export a file as a DXF. Only export to STL is available. I cannot imagine why they have done this other than to limit the free use of the software package. Personally I found eMachineShop very useful and user friendly for 2D technical drawings which could be quickly produced, exported as DXF then imported into Sheetcam for post processing before cutting. Fortunately I have a stand alone PC running on Windows XP which does not have automatic connection to the internet so can run an "old" version of the package.
  2. The Following User Says Thank You to Bladevane For This Useful Post:
  3. #2
    had the same happen to me came in form the workshop to do a quick drawing to export to cambam
    down loaded the update no dxf .my boy restored my computer to an early date it now works wont be downloading updates anymore
    I understand with your pain guys!
    Nothing much riles me more than when software updates or so called "upgrades" actually remove functionality without warning!!
    And in this brave new world this practice is becoming increasingly more common, with the biggest players being amongst the worst culprits!!!
  5. #4
    If you have control of software updates you should only be installing those you know you need to fix an existing issue, if your system works it's crazy to "Fix" it! :D
  6. Quite agree. If they had told me DXF export would no longer be available I wouldn’t have upgraded.
  7. I have been advised of a fix. Open eMachineShop, press Ctrl+Alt+e. Close and reopen eMachineShop. DXF option is available once "Export" is selected.
  8. I emailed eMachineShop and got this reply:
    "Thank you for reaching out. I am sorry for any inconvenience this update has caused you.
    You are correct that our beta export functionality to most file types has been disabled in this new release. STL export has been preserved.
    As a temporary workaround, please press Ctrl + Alt + E when in the workspace. Then go to the export dialog. You will notice full export functionality will now be restored.
    Please note that this workaround is not guaranteed to be available indefinitely. Depending on the feedback we receive we may restore export functionality to how it was, disable the workaround completely or offer another option. When this decision will be made has not yet been determined.
    I would be happy to share any feedback you have with management. Please elaborate a bit on how you use eMachineShop to design and manufacture parts, and why you do not use eMachineShop's manufacturing service to make these parts. This information will be very valuable in management's decision-making process."
    So all you guys who value the ability to export in a DXF format send your comments/feedback to eMachineShop. Use the form in Help - Provide Feedback.
  9. #8
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 1 Week Ago Has been a member for 9-10 years. Has a total post count of 280. Received thanks 2 times, giving thanks to others 69 times.
    Quote Originally Posted by Bladevane View Post
    Any way you could share the file to download for the original version please ?
  10. I can try. It will be version 1.932. PM me your email address and I'll load it onto Dropbox as it's nearly 20MB.
  11. The Following User Says Thank You to Bladevane For This Useful Post:
  12. #10
    Hi my name is Angelo Pacino, I am new member of the forum, I wanted to ask you if it is possible to have version 1.932 of eMachineShop,
    to export to dxf.
    I thank you in advance for your kindness.
    Angelo Pacino
    E-mail: [email protected]
There are currently 17 users browsing this thread. (2 members and 15 guests)
  1. Bladevane,
  2. jonhst
  1. PC Upgrade Options?
    By Chaz in forum General Discussion
    Last Post: 31-08-2016, 04:53 PM
  2. Laser Upgrade
    By dcrowder in forum Laser Machines & Building
    Last Post: 06-05-2016, 01:06 PM
  3. VFD upgrade
    By paulus.v in forum Spindles & Drive Motors
    Last Post: 05-11-2014, 11:09 PM
  4. Upgrade
    By Dopy in forum General Discussion
    Last Post: 09-11-2011, 01:57 AM
  5. BUILD LOG: Time for mk2 upgrade!
    By routercnc in forum DIY Router Build Logs
    Last Post: 26-02-2011, 11:38 PM
