    Hi
    I have a previous thread which I will update shortly
    I have constructed a desktop CNC
    I have a power supply with chinese characters above the 2 terminals
    I need to connect it to the spindle which has 2 wires black and red
    Wires from the power supply has a foil sheath.
    1. Will I do damage if I connect the wrong way around?
    2. How can I check which way to wire spindle. (black and red)
    3. Power supply is connected and has power
    4. Is it a good idea to earth spindle body?
    Many thanks
    DaveZ
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 7-8 years. Has a total post count of 472. Received thanks 103 times, giving thanks to others 43 times. Referred 1 members to the community.
    Quote Originally Posted by DaveZ View Post
    Hi
    Many thanks
    DaveZ
    Making the assumption you're talking about a 2 phase DC spindle, in theory, the spindle is just a motor - so which way up you connect it would determine which direction it spins. Without more information, I can't say for certain, but I wouldn't expect there to be a problem if it was connected with the opposite polarity.
    Always a good idea to earth the spindle, but be sure to avoid earth loops.
  3. The Following User Says Thank You to AndyUK For This Useful Post:
    Hi Andy
    Yes 2 phase DC. I had an idea wrong wiring would change direction. I've had one apart, no electronics inside. Also read about earth loops. Signal electronics and electrics are in 2 separate metal cases. Also graphite rings around heavy voltage wiring.
    Progress report: Mechanicals complete except for minor tuning of linear rails on Y axis. Electrics 98% complete. To do list. Touch up scratched metalwork, Download software onto computer, program Uno card. Commission and decide on engraving software. Looking at Desktop V Carve.
  5. #4
    Progress report or destruction report.....
    Everything wired up
    Ready to down load software
    Issues
    Spindle won't run ( I've had another one running previously )
    Spindle is brand new ( black and red wires show continuity on multi meter)
    Blew a fuse on spindle speed controller previously
    Currently.
    240v at input terminals
    Orange led on board lit.
    There is energy at output terminals, blew up multi meter........ probe in wrong hole on MM
    Previous use of MM sends needle off the right off range, I had dc voltage set to highest setting.
    Any advice or links gratefully accepted.
    Options
    Is it possible to measure output voltage with a MM
    What are the settings on MM?
    Any issues with using a laptop to run software. I have various older desktops if there is.
  1. chinese 500w spindle wiring
    By terry1956 in forum Spindles & Drive Motors
    Last Post: 14-01-2019, 11:52 PM
  2. FOR SALE: 4" Rotary Table with Stepper Motor & 4 jaw chuck
    By lateAtNight in forum Items For Sale
    Last Post: 21-10-2016, 02:36 PM
  3. FOR SALE: Er11 1.5kw spindle
    By adrpak in forum Items For Sale
    Last Post: 23-11-2015, 09:26 PM
  4. eBay: boxford 125-160 TCL chuck with spindle axis
    By sbdtasos in forum Items On eBay UK
    Last Post: 20-10-2015, 11:07 PM
  5. Replies: 1
    Last Post: 29-01-2013, 11:05 AM
