Guys - looking for someone who can machine an ally enclosure between the following min/max dimensions:
....... contacted 32 companies in the UK who advertise steel and alloy die cast enclosures for sale - not one could offer an enclosure between these sizes :whistling:.......... (yer, what's become of UK manufacturing? - that new steam engine that's just been built in the UK - we had to get the Germans - the Germans!!! - to make the boiler - this country, used to be the world leaders in steam engine design/construction)
Length (internal): 300mm – 310mm (min – max)
Width (internal): 100mm – 110mm (min – max)
Depth (internal): 32mm - 36mm (min – max)
Wall thickness: 3.5mm - 4.5mm (min -max)
Lid to go on top required - same thickness as enclosure wall thickness.
Aolly type: 6061, 7075 ... whatever, makes little difference.
If anyone out there is willing to take this on, drop me a note please. No such thing as a free lunch ... yes, thats understood.
Quite happy for someone to take this on on a "hobby" basis - theres no IP or DIN spec, or any other spec that has to be satisfied.
Thanx guys
14-10-2009 #2
16-10-2009 #3
Irving2008
Nope - no probs if the base is removable, and there is no issue regards edge radius - square, rounded .. whatever - use whatever tool you have. I'd say from true square to as much as 2mm - 3mm will be fine.....
What do
What do you have in mind regards fixture for top/bottom lids (?)- so long as the wall thickness is sufficient for small self-tapping type screws, that will be fine as I intend to cut a gasket in any case.
16-10-2009 #4
Have a look at Penn Fabrication's Module stage box system
A couple of lengths of their corner extrusion and a few plates of aluminium and bob's yer uncle...
Retail quantities can be bought from CPC:
http://cpc.farnell.com/_/10345-20/co...ule/dp/EN55970
16-10-2009 #5
I was trying to find 300 x 100 x 3.2mm ali box section but no one does it that size in ali only in steel.
machining it out of 1.75" ally plate is a possible, but its £25 worth of ali. However if you plunge cut it all the way through with a 10mm cutter at least you'd end up with an approx 280 x 80 remnant which is useful; then make top n bottom out of 4mm plate.
Another option is to make it up from 4mm plate and weld up the corners... then machine clean
Gosh that's brave, how are you going to hold it down and stop it bending away from the tool/galling once the temper has gone :naughty:
32mm deep doesn't exactly lend itself to small internal corner radii and the spec is too loose. Sounds like an invitation either to do a lot of drawing and not get the job, or chop up £25 worth of stock and then get told it's all wrong. I can see why he's having problems finding a volunteer :whistling:
17-10-2009 #7
Well, strangely enough, I was looking into ali welding for another problem and i came across Durafix which might do the job. Anyone used it?
Looking for a dremel sized cnc router
By isdngirl in forum Marketplace DiscussionReplies: 2Last Post: 29-04-2014, 12:01 AM -
RFQ: Some simple PAID precise Aluminium CNC work required completing? ANYone?
By justice86 in forum Projects, Jobs & RequestsReplies: 1Last Post: 03-12-2013, 08:12 PM -
FOR SALE: Nice aluminium rack mounted enclosure, possible casing for cnc electronics
By drumsticksplinter in forum Items For SaleReplies: 1Last Post: 24-08-2013, 12:48 AM -
Imperial sized lead screws?
By fentiger in forum Lead Screws, Nuts & SupportsReplies: 1Last Post: 14-06-2013, 10:16 PM -
RFQ: Need protective enclosure made from solid aluminium.
By Tinine in forum Projects, Jobs & RequestsReplies: 1Last Post: 12-02-2013, 09:12 PM
