21-03-2020 #1
Hi all,
Apologies if this has already been asked but I'm weighing up my design choices and wanted some input about the different arangment of x axis bearings. I don't know what or if these two designs have an official name (so i didn't know what to google) so I've called them alternative A/B
(The pros and cons are based on my limited understanding, so please correct me if I'm wrong)
Alternative A
Pros: easy to implement and calibrate how parallel the guide rails are, more travel than alternative B
Cons: Tool ends up being further away from the axis than with alternative B
Alternative B
Pros: Tools can can be held closer to the axis, better for rigidity
Cons, much harder to check how parallel the rails are, less travel than alternaive A
Most of the DIY machines I've seen use A, but it would be great to get the merits of each one.
About my build
Work area: 300x400x150mm, fixed gantry
Frame 50x50x3mm Mild steel
Spindle: Chinese 2.2KW water cooled
Intended cutting Materials 6082 Aluminium
Thank you
Looking for advice on the designs of these components for 3 axis CNC milling.
By Neil C in forum General DiscussionReplies: 5Last Post: 16-07-2017, 10:38 AM -
NEW MEMBER: Hello is anyone interested in swapping CNC furniture designs?
By robgibcnc in forum New Member IntroductionsReplies: 0Last Post: 17-06-2017, 08:39 AM -
FOR SALE: For sale Nema 34, single axis table (Not for CNC), ballscrew with rods, bearings/
By Desertboy in forum Items For SaleReplies: 1Last Post: 07-05-2017, 02:30 PM -
Y-Axis Designs
By Cyclonit in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 24-06-2014, 02:20 PM -
taper roller bearings vs deep groove ball bearings
By dsc in forum Linear & Rotary MotionReplies: 8Last Post: 10-03-2014, 08:06 AM
