10-07-2012 #121
Anyone trouble-shooting this module might find this and the hyperlinks shown there of some utility. http://www.drkfs.net/REVERSESTEPPER.htm
15-12-2012 #122
Hi everyone!
I just made a video of the Chinese fake TBA 6560 IC's.
If your order came from china, better to check them, before powering on.
17-12-2012 #123
I don't know where you found this information but according to the Toshiba data sheet pin 10 is power ground and pin 6 is signal ground so is not necessarily low impedance.
Pins 1, 17 22 are not ground as you suggest but are torque setting input, initial state sensing output, and excitation mode setting input, respectively.
Russell;
24-12-2012 #124
28-12-2012 #125
Ah, so what you are now saying is not that it is a fake IC but that it is an incorrectly marked one. Not the same thing.
Russell.
29-12-2012 #126
Do you really think that such a big and responsible company like Toshiba would sell "incorrectly marked ICs"?
Why can't we find any incorrectly marked IC at the stores, buy 15 of 20 from the ebay? It's a simple fraud.
This products should be destroyed in the company. So you think Toshiba made a mistake with tonns of their ICs?
25-01-2016 #127
try www.diycnc.co.uk
system45 newer driver boards so no more squeeling
22-08-2018 #128
I'm using the 5 axis board with no problem at all on a 3 axis mill.
Haven't set up the relay to a spindle yet.
I got 5 boards when they were £3.25 ish a while back. Been running the first one for over a year so far for 3*425oz/in Nema23's (Chinese 3 axis set from bay). All took less than 2 weeks to turn up. Strapped them to some cheap Chinese C7 1605 ballscrews and ended up with only 0.03mm of backlash. That'll do :)
https://www.ebay.co.uk/itm/CNC-MACH3...3lCvoTC38Ory7A
Once I get something bigger though I'd like to go usb instead of parallel.Last edited by dazp1976; 22-08-2018 at 05:35 PM.
There are currently 181 users browsing this thread. (0 members and 181 guests)
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.
By TommeyReed in forum Motor Drivers & ControllersReplies: 2Last Post: 06-03-2012, 06:01 PM -
FOR SALE: 4 Axis TB6560 Stepper Motor Driver Board
By Mad Professor in forum Items For SaleReplies: 1Last Post: 04-01-2011, 06:54 PM -
eBay TB6560 Stepper Motor Driver Boards
By irving2008 in forum Motor Drivers & ControllersReplies: 13Last Post: 07-04-2010, 04:48 PM -
manual for eBay TB6560 Stepper Motor Driver Boards?
By Dan Brown in forum Motor Drivers & ControllersReplies: 5Last Post: 06-01-2010, 10:37 PM
