25-10-2021 #1
I'm in the San Diego area of Southern Calif.
I program CNC machines for GKN (you might recognize GKN) aerospace here in El Cajon.
I make stuff from wood and metal "bits" ().
Decided to make myself a horizontal mounted CNC router to make dovetail corners, mortise-tenon joints and a little general routing.
I bought stepper motors/drives/power supply as a kit from Ebay, need to source a breakout board, ways and lead screws still. Will use Mach3 maybe 4 to control it. (Must be USB, parallel ports have gone the way of the Dodo). Oh, and the frame will be 1.25 11ga sq tube (roughly 32mm 3mm wall for the metrically inclined)
Just completed a 2 axis plasma table I bought online from Langmuir Systems. Had some issues with the lead screws but I think that has been resolved. It was a good starter for my CNC router project.
Glad I found the group.
FredLast edited by Fred101; 25-10-2021 at 08:18 PM.
29-10-2021 #2
Welcome to the forum Fred. Sounds like you have some useful experience to offer.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
30-10-2021 #3
Nah Parallel Ports are still are viable option for Linuxcnc. All you have to do is have a look on the Linuxcnc forum for recommended PCIe cards. Tho the Mesa FPGA cards are a far better alternative. Linuxcnc still will do the trajectory planning and the FPGA cards handles the step & direction timing, I|O and encoders.
These work fine https://www.ebay.co.uk/itm/254930870...5fa1b1072eb21c
30-10-2021 #5
31-10-2021 #6
NEW MEMBER: Hello from the other side of the pond.
By Sunrazor in forum New Member IntroductionsReplies: 3Last Post: 30-09-2020, 08:50 PM -
NEW MEMBER: From across the pond.
By 87bob in forum New Member IntroductionsReplies: 3Last Post: 03-08-2014, 12:55 PM -
NEW MEMBER: Hello for across the pond.
By 87bob in forum New Member IntroductionsReplies: 0Last Post: 01-08-2014, 09:05 PM -
RFQ: Gantry side panels
By fvfdrums in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-01-2014, 03:50 PM -
NEW MEMBER: New Member from Across the Pond-and an Introduction to My CNC Lathe Project
By acollins in forum New Member IntroductionsReplies: 2Last Post: 13-05-2012, 10:14 PM
