21-07-2015 #14
Backwards. Choose the RP size, gearing so that you have as a result normal rapid speeds with acceptable resolution. Then figure how many RPM you need in reality so you have mostly that in mind. Then you go back to the gearing ratio and gantry weight and from there you decide Nema 23 or 34.
Obviously as the RPM is the important part here cause most possible it will be well geared, then you finish with low impedance motors driven by high voltage.
And knowing that nema 23 motor driven at 70VDC moves a gantry max 50-60kg with gear 1:1 without problem at 10m/min via ballscrew, you can figure the motor you need for your case.
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM -
Motor size
By Philmollatt in forum Motor Drivers & ControllersReplies: 8Last Post: 15-10-2009, 08:39 PM -
What stepper motor size (torque)
By ZeroCount in forum Stepper & Servo MotorsReplies: 5Last Post: 09-02-2009, 11:54 PM
