    Quote Originally Posted by XYZ_Spec View Post
    It's already done for you inside the bags.
    Pre-mixed, just have to add water
    Lucky you. Pms share the name on the mix, i wanna see the technical data sheet and see what i can find close to it locally
    Quote Originally Posted by masinecc View Post
    Here it is the manufacturers site page for this product I've used.
    It seems to be only available in Portuguese language.
    This is the best I can do for you.
    https://www.cimpor.com/-/betao-seco-be-30
    Same...
    Thanks for sharing...
    What about this probe, how you finding it, accuracy etc?
    https://youtube.com/shortsNtOfxCaf4lU
    P.S Is it still v6: 3D Touch Probe Edge Finder ???
    .Me
    Yes Lee, V6.
    I like it a lot, and it's not crazy expensive.
    I want to install it permanently onto the spindle mount, this will allow me to set zero without having to do a tool change.
  5. The Following User Says Thank You to XYZ_Spec For This Useful Post:
  6. #15
    Hi guys,
    One year after designing and 3D printing a prototype that failed because it wasn't water proof, finally machined the housing from aluminum.
    I'm really happy with how it came out.
    It was a really cool project.
    Hope you enjoy it too.
  7. #16
    Nice, what finish did you use paint or anodised?
    .Me
  8. #17
    Spray paint.
    One day will anodize all the aluminum parts.
  9. #18
    Ok I thought so, keep an eye on the internal paint, the coolant *could* react with the paint and make it dissolve/flake off and block your spindle internal tubes, it should be ok I think but something to check later...
    .Me
  10. #19
    I'll keep an eye on it. I was hesitating to paint the interior bore, but I thought if i didn't try I would not know
    Thanks for your tip Lee
  11. #20
There are currently 27 users browsing this thread. (0 members and 27 guests)
  1. Damping Test of Concrete & Steel Tube
    Last Post: 16-05-2022, 01:26 PM
  2. Adding a Laser to my steel and concrete machine
    By Bongo in forum Gantry/Router Machines & Building
    Last Post: 16-05-2022, 12:28 PM
  3. Machining lighweight (AAC) concrete blocks.....
    By Voicecoil in forum General Discussion
    Last Post: 03-07-2020, 08:32 PM
  4. FOR SALE: Snowcrete Concrete - 14 x 25 KG Bags
    By Chaz in forum Items For Sale
    Last Post: 13-04-2019, 04:32 PM
  5. concrete base
    By reefy86 in forum General Discussion
    Last Post: 04-12-2017, 09:55 AM
