18-12-2023 #1
What driver do you recommend to power a Nema 14/17 I don't want to use the A4988's as this runs 24 hours a day I just don't trust they're up to it. I need good positional accuracy 0.1mm over a rotation (It's geared 4:1 so 800 steps) works I will have a home switch will I'll use to track and correct drift if it happens
But if I'm getting drift something is wrong and needs to be fixed it'll be interference.
Home is more there in case of power off I can recover where I was
It take X steps takes a photo, logs it's position to a file and then takes another X steps. I can use the log to restore to original position in case of power off
It's a timelapse BUT timed to steps NOT time
TB6600 sound OK? I don't want to spend a lot but it does need to be accurate and capable of running 24/7 for weeks at a time
It's rotating a lazy Susan, rotation rates will be very low as should torqueLast edited by Desertboy; 18-12-2023 at 03:51 PM.
Low torque steppers Nema 14
By Desertboy in forum Stepper & Servo MotorsReplies: 4Last Post: 13-12-2023, 08:16 AM -
DM860H driver and NEMA 34, 6 A, 8.5 Nm - configuration
By Emir in forum Motor Drivers & ControllersReplies: 0Last Post: 01-04-2023, 02:40 PM -
Help sizing your motor power and torque application
By Gary in forum General DiscussionReplies: 1Last Post: 14-12-2019, 11:25 AM -
Csmio-IPM wiring A nema 17 TB6600 driver Z axis THC
By Copypaste in forum CS-Lab (CSMIO)Replies: 0Last Post: 14-02-2019, 08:41 PM -
WANTED: 2 nema 23's 76mm long dual shafts 6.35mm plus one 56mm long nema 23 dual shafgt 6.35
By nobby in forum Items WantedReplies: 0Last Post: 24-09-2014, 09:57 AM
