Thread: Maximat V10P runs out
28-12-2023 #11
28-12-2023 #12
Yes, a check with my level shows that the bed has a twist in it, I can shim the mounting cabinet easy enough, will it correct the headstock I wonder?
28-12-2023 #13
28-12-2023 #14
Hi
Have a look at this
https://www.youtube.com/watch?v=dMP_F9wvb1c
ideally a No3 Morse test bar would be used.
I had to settle for the Emcomat 7 when i bought my lathe, the headstock on your machine should be in perfect alignment with the bed as it locates on the V section of the lathe bed, but it might have some clearance so it can be shimmed, however i don't think this is the case. Emco machines are of good quality and were priced accordingly.
Regards
Mike
28-12-2023 #15
Thanks, that is a very good video!
However my situation is that the headstock is not true to the beds, its pointing out towards the tailstock.
Anyway, bit by bit and with advice from forum users I am making improvments, today I removed the twist from the tailstock end, it was low at the back by over 4mm!
28-12-2023 #16
is there any clearance between the interface on the v section ie between hedstock and bed, can you get a shim between the bed and the headstock V section. do those two small screws allow you to move the headstock ?
28-12-2023 #17
If the base of the headstock was shimmed up I think some sideways wiggle will be possible?
Right now I am still hoping for a forum member who had the same problem and found out how to fix it?
The Maximat VP11 had paper shims.
28-12-2023 #18
Try asking here
https://groups.io/g/emcoV10lathe
28-12-2023 #19
Thanks, I tried that and the link to me to Kenwood 450TS ham radio!
I will have another go just now.
28-12-2023 #20
It worked for me, try this link
[email protected]
I sent an email initially (took a while for a reply) when i was after info on my Emco 7.
then you will get access to the forum.
Here ar some more links
[email protected]
[email protected]
There are currently 31 users browsing this thread. (0 members and 31 guests)
Replaced faulty driver, now that axis runs in reverse
By WRandall in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-10-2018, 07:42 AM -
RFQ: Looking for cnc turning of prototypes and if possible small production runs
By Rob in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-01-2016, 01:27 PM -
FOR SALE: Emco V10p for sale
By compositepro in forum Items For SaleReplies: 1Last Post: 07-09-2013, 05:46 PM -
Emco Maximat V-10 P
By Nielsvrijlandt in forum Emco LathesReplies: 1Last Post: 28-01-2011, 10:19 AM -
How to make a pickup winding faceplate that runs 'true'
By HankMcSpank in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 09-09-2009, 12:16 AM
