  1. Just by way of interest for prospective builders there is always discussion about what rod should I use... 12mm or bigger...
    Well here is the measured deflection of both 12 and 16mm rod (500mm long in SK type mounts) under 5kg load.
    In this experiment the mounts were not clamped up nor were they bolted down so the deflection of the rails themselves will, in reality, be less than this although the MDF base will deflects some as does the MDF 'table'.
    2 x 12mm rod = 0.25mm (theory .08mm for rigidly fixed ends to .3mm for unfixed ends)
    2 x 16mm rod = 0.1mm (theory .025mm to .1mm as above)
    (i.e. if the clamps aren't tight and the supports not bolted down the rod flexes more)
ID:	59   Click image for larger version.
    Last edited by irving2008; 01-09-2008 at 10:02 PM. Reason: was 16mm not 20mm the bigger one!
    Whats on the dials as read outs mate?
  3. errrmmm... 0.25mm and 0.1mm :)
    Quote Originally Posted by Kip View Post
    :rofl:
    Pretty bendy stuff but average joe probably wouldn't be bothered (or know to be)
    Quite. I think it depends on the intended purpose of the machine too. For instance, I'm not going to be bothered about even .25mm deflection when I'm routing a house sign. On the otherhand, I would like good precision if I'm milling a mold for a modelling project. I'd like to see the results of the same experiment done with the ends properly clamped and bolted down to a firmer surface than MDF. I bet a clamped rail bolted down to a steel base would fare better.
    Since I'm running 1m unsupported 20mm rails on my machine I may well do just that.
  5. Quote Originally Posted by Kip View Post
    :rofl:
    I'm surprised how rigid that stuff actually is...
    12mm probably good enough for a PCB miller on the X-axis supporting the table, with 16mm on the Y axis and 12mm on Z. I think 20mm is prob required for a lightweight ali miller on X and Y with 16mm on Z
    Fully supported rail with open bearings is best but harder to work with...
  6. Quote Originally Posted by Kip View Post
    It'd be fine for a machinable wax router...cheap as chips too.... How bendy are 30mm supported rails 1.64m long mounted top and bottom on 75mm 4mm wall thickness 356? If you like numbers ;)
    not very... fully supported rails are very solid....
    I'm about to start work on a mill i plan to use for PCB's and 12mm rail was the choice, i have rail to hand and so i can use other sizes at what point would we not see any deflection, with this info i could work out if the weights i plan to move would be a problem on 12mm rails ;-) keep up the good work !
    CM
  8. there will always be deflection.... the question is at what point does the deflection become to small to be of interest.... clearly if you are aiming to mill Ali to .01mm tolerance you need something that wont deflect more than .005 under cutting load.... remembering that deflections combine... movements in gantry, table, etc all add up...
    I want to build table 1.2x0.8 meter.I will use supported 16mm rails on 1.2m long side.On 0.8 what have to use to have no deflection - supported rails 16mm or 20mm unsupported.
  10. Quote Originally Posted by shulio View Post
    Depends on the load - two 20mm unsupported rails will each deflect 0.5mm approx under a 10kg load. Supported rails are better (they do deflect but its tiny compared to unsupported)
  1. How much deflection to expect...
    By Wal in forum Gantry/Router Machines & Building
    Last Post: 04-02-2014, 10:41 AM
  2. Precision metric bolts
    By mart154 in forum Marketplace Discussion
    Last Post: 15-12-2013, 09:36 PM
  3. maximum deflection - sanity check
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 11-02-2013, 09:33 AM
  4. RFQ: looking for a cnc / precision engineer
    By jonisonvespa in forum Projects, Jobs & Requests
    Last Post: 29-11-2012, 05:44 PM
