    So maybe if I decide to go down the route of buying a USB parallel emulator, which one should I get - I've heard of SmoothStepper but have seen others too.
    Only ones I know of for CNC use are the SmoothStepper, and the ncPod.
    However nothing has been heard of from the ncPod guy for quite some time.
    The SS seems to be the way to go just now.
    If you register on the SS website - www.warp9td.com - you'll get access to the forum (I'm pretty sure it's hidden unless you're registered).
    There'a also support forums on the machsupport site for the ncPod and SS, which are pretty active.
  1. USB TO Parallel Port DIY Interface
    By Lee Roberts in forum Electronic Project Building
    Last Post: 17-02-2018, 07:46 PM
  2. What is the function of a parallel port breakout board?
    By hbx in forum Machine Control Software
    Last Post: 12-03-2013, 06:18 PM
  3. Stepper motor drive using mach3 from parallel port
    By hmarwat370 in forum General Electronics
    Last Post: 04-02-2013, 08:55 AM
  4. parallel port address
    By Dan Brown in forum Artsoft Mach (3 & 4)
    Last Post: 07-01-2010, 12:04 PM
  5. Laptop, ie no parallel port?
    By tompsky in forum Laptops & Tablets
    Last Post: 11-11-2008, 07:12 PM
