    The last mechanical component I need to source for my z-axis is a 72tooth HTD 5mm pitch by 25mm wide, preferrably in alloy.
    HPC do them at £££, RS only stock Gates (Gates use Cast Iron at that size), and I can't remember the name of the company usually recommended by the model engineering lot.
    I also need a belt and a 24t for the motor, but they're easy enough to source.
    Any suggestions?
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    bump...............
    .Me
    Have you tried Huco? They're cheap for racks, not tried them for puleys
    http://www.huco.com/products.asp?p=true&cat=318
    Oh, totally forgot about this.
    I just went to HPC for the required pulleys. It's only for the one axis, and they had them in stock. For all the money I was likely to save, it didn't seem worth the hassle to try and get them else where.
  1. Timing Pulley/Belt sizing software
    By m_c in forum Computer Software
    Last Post: 12-04-2014, 03:33 PM
  2. Making timing pulley - putting theory into action
    By wiatroda in forum Metalwork Project Showcase
    Last Post: 28-11-2011, 02:22 AM
  3. Increasing timing pulley bore size from 3mm t0 3.175mm
    By divdav in forum Gantry/Router Machines & Building
    Last Post: 14-05-2011, 09:45 AM
  4. 4th Axis timing pulley + Axminster bandsaw review
    By Jonathan in forum Metalwork Project Showcase
    Last Post: 09-04-2011, 07:31 PM
  5. help needed drilling bore hole in mxl timing pulley
    By geekinesis in forum Gantry/Router Machines & Building
    Last Post: 02-02-2011, 01:07 PM
