    I'v just recived one of these from a seller on ebay:
    2GB USB flash / memory / data stick - swivel (black) - NEW
    The Swivel has a metal sleeve over a soft touch rubber coated or transparent plastic body. The rotating sleeve protects the USB plug, no separate lid required.
    Please note these are old stock of data sticks which may have some slight marks / scratches to the outer metal case, but are brand new and never used. (mine was in mint condition)
    Specification:
    100% new high quality 2GB Flash Drive Fold
    Capacity : 2GB
    Read 12MB/s and Write 8MB/s Compatible with All VR3 Products VRFM7 , VRFM8, VRFM9,VRCD400USB and VRCD400SDU Works on all Major Operating Systems, PCs, Macs, Laptops
    Support Hi-Speed (480Mbps)
    Mobile USB Flash Drive, USB 1.0/1.1/2.0 Compatible
    No Drivers Required
    Durable Solid-state Storage and Data Retention for at Least 10 Years
    Low Power Consumption
    Key Chain Dongle Design or Can Use Strap, Easy to Carry
    Dimensions : 5.5cm (L) x 1.8cm (W) x 0.6cm (H)
    Weight : 0.016 kg
    Support Windows 2000, Windows XP, Windows Vista
    The seller is nothing to do with me but i can confirm the sticks he is selling are A OK, and for £3 delivered you cant go wrong !
    I only needed a couple of these to use as linux boot drives for somthing i'm working on, so 2GB's was more then enuff for me. If you need a massive amount of space then im sure there is lots of other better deals on the bay for bigger sticks but if you just want a quick, simple, CHEAP stick then grab some of these before they all go.
    EBAY ITEM NUMBER: 140289282648
    EBAY LISTING LINK: http://cgi.ebay.co.uk/2GB-USB-flash-...ayphotohosting
    .Me
  1. Flash POP Warning
    By longy in forum Metalwork Discussion
    Last Post: 18-03-2014, 10:45 PM
  2. The Journey begins.. new to me.. my first CNC - Black Cat
    By Fivetide in forum Milling Machines, Builds & Conversions
    Last Post: 22-10-2012, 05:48 PM
  3. Has anyone got/used a machine from Black-Cat-CNC?
    By cjpwart in forum Milling Machines, Builds & Conversions
    Last Post: 12-08-2012, 05:15 AM
  4. Dial Test Indicator (DTI) swivel clamp
    By Vikash in forum General Discussion
    Last Post: 21-10-2010, 01:59 PM
  5. Stick with Ali profile or venture into plate?
    By ecat in forum Metalwork Discussion
    Last Post: 22-08-2010, 09:00 PM
