This is driving me nuts. Last night I started wiring up my PSUs, drivers, and motors. All the standard Zapp/MCP kind. Wired everything up as per the diagram provided by MCP. Plugged it in and the PSU has a green light, but the drive has a red one! I have checked my wiring against the note about a hundred times! I tried both series and parallel, tried different drives, different psu. Nothing works!
This is the wiring I am using:
A+: Blue + Red
A-: Blue/white + red/white
B+: Green + Black
B-: Black/white + green/white
Could someone please check the attached pic and tell me what I have done wrong? I have wired these things up before without problem.
Cheers,
Dave.
29-04-2009 #2
We have seen this problem before, another PSU in parallel with your current PSU should fix the problem.
Let me know what size PSU you’re using and I’ll give you a price, i would also suggest doing the linking at the motor end as well..Me
29-04-2009 #3
I don't even know if I want to admit this...
But as it turns out the problem was the PSU. One of them is a PS407, the other is a PS705. The 705 is rated at 70 something volts, and the drive only takes something like 48 if I remember correctly.
Anyone want to buy a PS705 unit? :D
Keith: Indeed I am back home, putting the finishing touches to the machine finally :). The phone was flat, again. You mind if I give you a call tonight? Need some advice on setting up mach if thats alright. Also, I'll need a nice thick table with t slots made up. If you interested in a little work.
Dave.
Proximity Wiring Problem
By Bruce in forum General ElectronicsReplies: 7Last Post: 13-01-2014, 07:21 PM -
dc motor - spindle / shaft drive
By dsc in forum Spindles & Drive MotorsReplies: 21Last Post: 01-06-2013, 10:42 AM -
DC motor drive circuit?
By Tenson in forum General ElectronicsReplies: 4Last Post: 02-02-2012, 10:32 PM -
Stepper motor wiring
By Buba b in forum Stepper & Servo MotorsReplies: 5Last Post: 28-03-2010, 06:16 PM -
Motor problem
By irving2008 in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-09-2009, 01:06 AM
