  1. If, for some reason, you want to feel inadequate: Have a look at this guy's work
    http://www.youtube.com/user/00CrazyDiamond00
    Bill, I felt inadequate when I followed you renovating that lathe, this is just sick :)
    BTW,
    Just posted on the Yahoo Mach group
    [ame="http://www.youtube.com/watch?v=q_-uHyJNVxs"]YouTube - Portable CNC milling machine[/ame]
    Answer looking for a problem?
    JEff.
  3. You having a bash Bill?
    I have plans:
    An MD30 drill/mill to conversion, which has been on hold while I fixed up the lathe. I have made a couple of DC servo boards (Max-Mod's pic dsp based design) for it and have yet to design the Z axis mechanism (which might be a planetary traction drive to the rack and pinion). Oh yes and I've yet to fix the broken servo motor encoder - I bought a bargain encoder wheel, only to find my two channel reader unit wont read the three channel encoder
    And, a bed-top cnc adapter for the HLV, (similar to this [ame="http://www.cnczone.com/forums/showthread.php?t=75106"]Feeler conversion[/ame]). I bought an extra width Hiwin slide from the US the other day with the intention of using it as the cross-slide with a single, but when I tested the idea (by clamping it the Hardinge's carriage) there was a little too much play in the Hiwin truck to be useable (a new set of bearing ball might fix it).
  4. Looks like a job more suited to crossed roller bearings
    Yes they would do it. However, the 'problem' forces, in-feed and reaction, are small (the majority of the force is straight down). I was easily able to hand feed the tool to face a part, even holding the tool to turn down the piece wasn't too hard. Accuracy is only effected if the carriage/truck flexes away from the part (because the feed screw will be some distance away from the tool). The problem with my Hiwin MGW slide is that is has a small amount of clearance (it's not a pre-loaded type).
    Any images of the traction drive?
    I haven't even designed it yet!
  1. Replies: 0
