Thread: new laser
31-05-2009 #2
I was trying to start a 'bring a bun' policy for all non-purchacing visitors, but biscuits will be fine, how about hobnobs with caramel. Or better still if we have some bits that you want we could swap them for their weight in biscuits, might have to set some limits, perhaps a minimum payment of 2 biscuits and no maximum
We have removed the floor to fit the laser (this is the 'royal we' as I've done nowt due to a brief holiday). The laser is very big and heavy, uses a heidenhain cnc and a moving table, ballscrew and spinning nut, looks to weigh about three tonnes, which might be a struggle for our 2 tonne crane.
Mike
Techserv
31-05-2009 #3
Mike,
It may pay you to remove the laser off the top whilst installing the machine.
If that takes a knock it's virtually impossible to get back aligned again.
Those Ferranti's can be pigs to tune.
Early ones were filed with Fluorocarbon, later ones deionised water, whatever happens make sure the ballast resistor box in the bottom is bled before starting, one air bubble and it frieds the ballast resistors, - don't ask.
.John S -
06-06-2009 #4
Thanks for the advice John, laser removed to a place of safety, in fact almost every thing removed, too bloody heavy to lift with our crane. Now in position ready for a rebuild, might have a bit of a hunt round for a higher power laser. I'm told there is a chap in Wakefield deals in them. Water jet machine going togerther shortly and looking out for a 3 metre pressbrake.
Thanks for calling in Kip, sorry to have missed you, had to do the holiday thing, next time perhaps. Did you get the full tour of 19,000 square feet of junk or just the main workshop?
Mike
Laser cutter
By John S in forum Laser Machines & BuildingReplies: 8Last Post: 02-06-2012, 02:16 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
RFQ: Cnc or laser cut steel brackets
By don_jarr in forum Projects, Jobs & RequestsReplies: 4Last Post: 12-04-2012, 09:23 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM -
Laser power
By John S in forum Laser Machines & BuildingReplies: 9Last Post: 26-08-2009, 09:53 PM
