Thread: sieg kx3 cnc mill
08-10-2019 #16
Depends if you want to make £money with it or just use it for hobby use with the BIG question of how much are you prepared to spend.
I have a much older Syil SX3 @3500rpm & with a little TLC she can kick out some very accurate parts with good surface finishes in ally. You just need to experiment with feeds & speeds until you hit your sweet spot and never take the various calculators speeds for granted. I use cutters from 1mm upto 16mm in mainly 6082 t6 & get great results from engraving right through to 3d carving.
Your biggest plus with going with a KX3 would be the user base is at your level and prepared to help with what might seem unsurmountable problems to you at first but usually turn out to be the small niggles that are just part of the learning curve. You don't get that with the pro machines . . . .
Sieg - KX1
By ptjw7uk in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 31-07-2016, 11:25 AM -
FOR SALE: Sieg x3
By andris in forum Items For SaleReplies: 4Last Post: 25-02-2014, 06:32 PM -
Sieg KX3
By gently in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 10-09-2011, 11:42 AM -
Sieg SX2 in the UK?
By TheChunk in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-09-2010, 03:00 PM -
Number plate dies and a Sieg KX3 CNC Hobby Mill
By p4tvw in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 14-04-2010, 04:51 PM
