Such a simple job, two brackets to connect an electric hoist to scaffold tubing up in the roof.
Pop a scaffold pipe sized hole through two pieces of box section, what could be easier. It's only 10 gauge
Couldn't find the ordinary box section, could only find stainless. Felt dread.
Lost a tooth or two on the bandsaw cutting it to length. £12.50 a blade.
Knew the mill wouldn't pierce it, decided to drill it 12mm first. Drill goes red hot and burns out.
Milling cutter doesn't want to open the slightly undersized hole out. It's bending the box section until it can stand no more then leaping back. Never seen that before. Turn off the CNC and drive it through by hand, cutter will never be the same after that.
CNC the hole bigger, table leaping all over the place. Ball screws displaced, backlash now 2mm, second part comes out undersize, table in need of repair.
Lock the slides and try to make it round with a boring head. The carbide tip soon shatters but there is one sharp edge remaining about 4mm back from the end and I get it done. This is becoming a war of attrition and I'm losing.
Now just 4 x 10mm bolt holes left to drill and I'm done. At that point I gave up for the night and came home.
Wonder how many drill bits I can nadger tomorrow.
08-02-2009 #2
Ekk!
I'v spent all day trying to hack a linksys router to use linux and do a few other things only to now have a "guy" doing everything remote for me.
Crap day for me to, your not alone. Time for Mrs Roberts/Hewitt, snugs on the sofa time !.Me
08-02-2009 #3
Must be one of those days, switched the desktop computer on this morning to do some drawings for the laser cutters and the CAD program got slower and slower.
Re booted and it hung on the splash screen.
Get it checked and the chip has died, modern chips won't fit this motherboard so new motherboard and chip later it won't read the original raid array on the drives.
Now got to rebuild the raid arrays and hope it doesn't loose any data. Laptop is working but this doesn't have email enabled so new drawings can't be sent.
John S.
08-02-2009 #4
What speed were you drilling? Rule for stainless is low speed high feed. Stainless when you buy it is soft but work hardens very quickly indeed. Once the drill starts to chatter or you see black swarf, you have lost. If drilling with a pistol drill, I find the best method is again, slowest speed, lots of pressure and pulse the drill, short 2 second pulses will get you through in no time and you will be surprised how many holes you can drill before the bit needs sharpening. Cutting fluid can also help but can also make the drill cut too deeply as you really do need to keep the pressure on to get through the "chewey" stainless.
I would have gone for a hole saw on slowest possible speed, a light touch pressure wise and good cutting/tapping fluid (not mystic). I know this is opposite to drilling but this is with the benefit of 30+ years of doing it day in day out.
Jeff.Nothing is foolproof......to a sufficiently talented fool!
08-02-2009 #5
Have you looked at the NSLU2?
Wonderful little device. I have one remotely with 2 750Gb drives attached which contain my backups and runs our whole house Itunes service to Roku Soundbrige 1001's
Does this read the way I think it does?
Jeff (confused)Last edited by Smiler; 08-02-2009 at 06:06 PM.
I know what went wrong, I pushed too hard at break through and the metal extruded in to a collar on the inside of the tube. This collar instantly hardened undersize and started deforming to match the bit as it went round. Less than a second later the bit was red hot and deforming to match the collar
I got my 4 holes drilled this morning nil problemo. Should have binned the rest of the bar but didn't :D
08-02-2009 #7
Stainless is an absolute pig! It's so temptimg sometimes when you are microns away from breaking through and the swarf turns dark to push just that bit harder.......next thing you know....home made step drill:D
Wasn't trying to teach you to suck eggs BTW.
Snowing buckets here at the 'mo :(
Take care all, Jeff.Nothing is foolproof......to a sufficiently talented fool!
RFQ: Water or laser cut stainless flanges
By r0bsk1 in forum Projects, Jobs & RequestsReplies: 2Last Post: 23-09-2013, 08:12 PM -
How to cnc cut 1-2mm stainless sheet ??
By Ricardoco in forum Metalwork DiscussionReplies: 9Last Post: 28-03-2013, 04:06 AM -
stainless steel fasteners - quality
By dsc in forum Metalwork DiscussionReplies: 7Last Post: 30-11-2012, 12:35 PM -
Mini lathes - possible to turn stainless?
By HankMcSpank in forum Lathes, Lathe Rebuilding & ConversionsReplies: 27Last Post: 03-08-2010, 03:14 AM -
Grumble moan complain
By Robin Hewitt in forum Machine DiscussionReplies: 1Last Post: 07-10-2009, 10:54 AM
