    So.. after much trolling this and other cnc websites, youtube and all the other stuff you end up looking at whilst researching, I finaly ordered up some AC servos, a VFD and a CS Labs CSMIO IP/A with I/O expansion and MPG module.
    Being that this lot cost a fair lump of cash, I want to be VERY carefull in getring the wiring correct.
    I get the majority of the connections, but wanted to make sure that all was correct before I started.
    I emailed CS labs for help, asking if they could do a quick connection diagram for a servo drive and for VFD ( literature supplied), as none on the diagrams on their web site, fully matched up with the drives I have.
    ( is it just me, or does an ISO standard for terminal identification not exist yet for drives)
    The response was far less than I would have expected, for a company pitching their goods at industrial users.
    It was basicly " busy, may be able to help in about 8 weeks".
    What!!
    A.C. Servo drives are AASD-20A
    ( CONTROL VIA -10V~+10V)
    VFD is a chinese 9100 series 2.2KW
    ( speed control 0-10V +fwd, rev, stop)
    Anyone got experience of wiring these in to an IP/A?
    Attached Thumbnails Attached Thumbnails 9100 User manual.pdf   Click image for larger version.
ID:	25197   CS Labs CSMIO IP_A connections.pdf
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 3 Days Ago Has been a member for 9-10 years. Has a total post count of 1,605. Received thanks 110 times, giving thanks to others 69 times.
    Ye, they *might* make good kit but never really been impressed with them post sale.
    I can show you how to wire the stuff, not too difficult. Is that the driver manual / image of the connections page?
    Chaz's Avatar
    Quote Originally Posted by swarf-boy View Post
    What!!
    Is the VFD made by a company called ECOGOO ?
    Hi Chaz,
    Yes that's what I was able to attach.
    I have also just attached an xcel spreadsheet I did, showing everthing I have worked out so far.
    ( probably a bit unconventional, but it seamed a simple way to plan it)
    Feel free to mark my homework...... LOL.
    Comments welcome from all.
    Chaz's Avatar
    Hi Chaz,
    I dont see the spreadsheet. Can you put it on googledocs or dropbox or similar? Else I can pm you my address.
    I did the same (excel) for one machine I retrofitted (IP-A with Mitsubushi servos).
    Chaz's Avatar
    Hi Chaz,
    Ah, didnt see you updated the original post. Ill take a quick look. Actually, send me your email address and Ill dig out what I did.
    Pm sent mate
  9. wont your new drives run position mode? step/direction?
    would make it much easier to set up and would have saved getting the csmio.
    i can help you with the ecogoo .
  1. Upgrade questions fro beaver mill VBRP Mk2 with Anilam Crusader II controls
    By Breg90 in forum Milling Machines, Builds & Conversions
    Last Post: 25-05-2020, 08:08 PM
  2. Upgrade to x axis required. MG or HG rail
    By marbles in forum Rails, Guideways & Bearings
    Last Post: 10-12-2017, 01:51 PM
  3. CONVERSION: Novamill mach conversion upgrade
    By Benja in forum Conversion Build Logs
    Last Post: 18-09-2017, 09:23 AM
  4. Emco pc mill 55 upgrade
    By Craiggillzzr1400zx10r in forum Emco Milling Machines
    Last Post: 31-08-2016, 03:13 AM
  5. picture conversion to DFX/ Gcode. Help required please.
    By Gasgasbones in forum Programmers Corner
    Last Post: 19-12-2014, 11:42 AM
