Thread: Alignment
23-12-2023 #1
Hi, I hope someone can tell me, why my machine is working back to front.
Mach3 shows it working as it should. It is set for the dentre of the material, and shouls start at the back side of the material then move to the front, but it is starting at the front then moving of the workspace to try and cut the next piece. what is going wrong, never had the problem before.
25-12-2023 #2
If you need to reverse the positive direction of an axis under Config - Motor Home/Soft Limits, Check the Reversed column for the Axis you need to reverse.
25-12-2023 #3
Thanks to u, #2. But it is like this forum is not active enough. Less replies to thread, week-old latest thread...
25-12-2023 #4
axis alignment
By mkultra in forum Boxford LathesReplies: 0Last Post: 12-11-2021, 12:47 PM -
ballscrew to stepper shaft alignment
By marbles in forum Belt Drive, Pulleys & TimingReplies: 10Last Post: 22-09-2021, 09:59 AM -
SH-350 Mirror alignment
By Wolfster in forum Laser Machines & BuildingReplies: 16Last Post: 30-03-2016, 03:47 PM -
Boxford TCL 160 tool alignment
By Saracen in forum Boxford LathesReplies: 2Last Post: 05-11-2014, 10:28 PM -
Mini Lathe alignment
By pequod in forum Lathes, Lathe Rebuilding & ConversionsReplies: 2Last Post: 29-06-2009, 06:40 PM
