Thread: Cambam / pocketing question
31-03-2024 #1
So I have a piece of 20mm thick 6068 aluminium (400x300) .
I know I can create holding tabs in cambam when profiling.
Instead of cutting around a piece via profile, I am pocketing around the outside of the piece to be less harsh on the 6mm single flute endmill (although it will have a lot more material to mill) and also I will get much less vibration . I’d like to know if there is a way in cambam to avoid areas while pocketing to avoid clamping areas ? Then I can move the clamps once done to finish.3 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle..... CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
cnc router x axis starting before y axis finished when pocketing ?
By Robin Oakapple in forum General DiscussionReplies: 16Last Post: 30-08-2020, 11:09 AM -
Trying to fathom cambam
By John11668 in forum General DiscussionReplies: 6Last Post: 09-07-2020, 09:09 PM -
CamBam / FreeCAD 2D/3D MOP question Please help
By dudz in forum CAD & CAM SoftwareReplies: 18Last Post: 30-08-2014, 09:11 PM -
Some general questions. Drilling and pocketing.
By Wal in forum Metalwork DiscussionReplies: 1Last Post: 15-02-2014, 12:05 AM -
Mach3 / cambam
By dudz in forum Artsoft Mach (3 & 4)Replies: 5Last Post: 01-04-2013, 06:02 PM
